Motor???
Old Aug 1, 2008 | 04:55 PM
$300vett's Avatar
$300vett
Default Motor???
I have a 85 vette-- It had a Jasper LT-1 motor installed in 2000.. Called Jasper to find out what was the HP-- Don't know if it is a class 1(230HP) or a class 2(with around 290 Hp). Called them and they told me to look for a red tag by the freeze plug.. Well of course I dont have a red tag by the freeze plug.. Talk to Jasper and they don't have another way to tell me.. Tried to locate the last owner--no luck... Can anybody tell me is their another way to find out the motor HP besides putting it on a Dyno??? You would think I would be able to tell just by driving it but I just don't know.....
Thanks $300vett
Old Aug 5, 2008 | 01:33 PM
$300vett's Avatar
$300vett
Thanks $300vett
Come on guys somebody must have some idea's
Old Aug 6, 2008 | 09:53 AM
Elephanthead's Avatar
Elephanthead
I would think you could tell by driving it 60 HP is a big difference. Have someone with an stock 85 take you for a spin and compare. In the end it doesn't really matter, you are either happy with the performance or not.
Old Aug 6, 2008 | 12:12 PM
$300vett's Avatar
$300vett
Thanks but I am not happy with it--- I would like to make some changes but I think I need to know what I am starting with.... And yes you would think I would no the difference but I just couldn't tell you.... but thanks anyway.
$300vett
Old Aug 6, 2008 | 01:07 PM
kalister1's Avatar
kalister1
This will not work, stock 85's do not have an LT-1. Maybe you can drop the pan and look for 4 bolt mains? The vettes had 4 bolt and I think everything else had 2.
Old Aug 6, 2008 | 01:22 PM
$300vett's Avatar
$300vett
The LT-1 was installed in the 2000.... so it is not a stock motor... Jasper put out 2 different LT-1 motors-- a stock and one with more HP....
thanks $300vett
Old Aug 6, 2008 | 05:43 PM
blkvette85's Avatar
blkvette85
Corvettes had 2 bolt mains. An 85 should be an l98. Only 1 engine ava. the 230 horse I believe.
Old Aug 6, 2008 | 06:09 PM
cwyates4's Avatar
cwyates4
Can you find a pic of what the engine looks like? Then we could tell you what it is.
Old Aug 7, 2008 | 07:42 AM
MTVette's Avatar
MTVette
If you don't want to put it on a dyno, then the next best way is to take it to a quarter mile drag strip and do a few runs. Again, 60 HP shouldbe pretty apparent. Let us see your numbers from the track, and we'll give you a good guess.
Old Aug 7, 2008 | 10:12 AM
$300vett's Avatar
$300vett
Thanks I will take some this weekend and post...... thanks
Old Aug 7, 2008 | 10:16 AM
$300vett's Avatar
$300vett
I am currently in Lynchburg VA I cannot find a dyno close... I am looking for one that is not 500 miles away..... I stay in Roanoke Rapids NC but cannot find one close by.. But I am most willing to put on a Dnyo....
Thanks again
Old Aug 8, 2008 | 12:01 AM
$300vett's Avatar
$300vett
cwyates4 I sent a PM but I figure out how to put them in my album... Thanks I will post some of bottom end on Friday.... Thanks
Old Aug 8, 2008 | 12:23 AM
cwyates4's Avatar
cwyates4
The pics in your profile are of an L98 with tuned port injection, No Lt1. More than likely, its the "230 hp" one. For it to have 290, it would need a decent cam and heads, which you would probably notice.
Old Aug 19, 2008 | 09:07 PM
89er's Avatar
89er
Thanks $300vett
I'll bet they used different rocker arms on the diffent engines. Maybe if you pull the valve covers you'll be able to tell.
Old Aug 20, 2008 | 07:26 AM
kalister1's Avatar
kalister1
Lt-1 Corvette engines are all 4 bolt mains! This is a replacement engine, an LT-1 according to the OP.
Old Aug 20, 2008 | 08:12 AM
$300vett's Avatar
$300vett
Not sure what is now....... the last owner said it was a jasper LT-1 motor.... but posted some pics and everyone said it is a L-98....
Thanks kalister1
Old Aug 21, 2008 | 12:58 AM
johnnyevans's Avatar
johnnyevans
Looks like an early L98 to me.
YES, the LT1s and the LT-1s are 4-bolt mains, in the vette. geesh
Ever seen a LT1 with perimeter valve cover bolts? LT-1 yes
To Motor???
