Does anyone know if there are any differences between 13" front rotors for C4s and those for C5s? I am in the middle of a brake job and realized that the part numbers for my new front rotors match up to a C5 not a C4. If it makes any difference, I am running 96 grand sport calipers and brackets.
As long as the rotor thickness is the same 1.1" and the measurement from the top of the rotor hat to the bottom of the rotor are the same, they should fit.
I just installed the 13" GS calipers using Wilwood rotors and they measure 1.1" ( The Wilwoods must be a little thicker than stock). I wouldn't think the C5 and C4 rotors would be the same thickness.
These are ACDelco rotors, so I just looked up the images on line, and I don't think they will work. The C5 hat comes up at and angle and then flattens off, but the C4 hat comes up at an angle then has about a 1/4" to 3/8" spacer on top of the hat. I probably didn't describe it very well, but the wheels would be pushed in more and may rub on the calipers due to this difference.
