Fuel pressure....
Old Aug 2, 2008 | 07:03 PM
pearlvett's Avatar
pearlvett
Default Fuel pressure....
What is the recomended fuel pressure on an 85 with free flowing intake and exhaust?
Old Aug 2, 2008 | 08:56 PM
John A. Marker's Avatar
John A. Marker
Ignition on, hose disconnected to pressure regulator and plugged...pressure should be between 34-39 psi.
At idle...pressure should be 24-36 psi
Old Aug 2, 2008 | 08:59 PM
schrade's Avatar
schrade
There's some recommended specs for fuel pressure in a magazine article I posted up. Search 'Tuning TPI'...
Mr FICINJECTORS has the article now, and tons more info...
Old Aug 2, 2008 | 10:22 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
according to the article they say that the 85 is 40 psi.. I tend to differ with them. 85 rail pressure should be 36. the 85 uses 24lb injectors because there were no 22's. The fuel pressure was lowered to 36 to make the 24 bosch flow 22 actual. in 86 they used a 22 rated at 43.5 psi.
Old Aug 5, 2008 | 04:53 PM
pearlvett's Avatar
pearlvett
Thanks for the info.
To Fuel pressure....
