Rear View Mirror question.....sorta technical....
Old Dec 31, 2001 | 01:35 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Rear View Mirror question.....sorta technical....
was wondering...if anybody has had this problem...and if so...how do you get rid of the stuff...
My 1990 still has its original rear view mirror and I was wondering...it had developed a scum like brown corrosion on certain places on the mirror....how do you get rid of it...?...or can you? it seems to be within the mirror almost...I have tried all sorts or powerful cleaners....nothing touches it....
I have even touched it and scatched it with a razor knife...like I said...seems to be embedded in the mirror....?
I mean I can live with it...and don't really want to pay like $100 to get a new mirror....so any help much appreciated....
thanks jeff
Old Dec 31, 2001 | 01:49 AM
bogus's Avatar
bogus
Default Re: Rear View Mirror question.....sorta technical.... (XtremeVette)
the silver is going bad... you need to replace... I don't think you can just replace the glass in these...
Old Dec 31, 2001 | 01:50 AM
AS84's Avatar
AS84
Mine has the same spots and I believe its under the glass. I've heard that they only way to get rid of it is replacing the mirror :(
Old Dec 31, 2001 | 06:20 AM
Ruby_Roadster's Avatar
Ruby_Roadster
Bogus is right - it's the silver going off - take the mirror assembly apart and take the mirror to a glass place that makes mirrors, they will be able to cut you one to size then just put the mirror assembly back together back together - a lot cheaper than having to buy a complete new mirror.
Old Dec 31, 2001 | 06:44 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Re: Rear View Mirror question.....sorta technical.... (Ruby_Roadster)
Some problem here, plus mine is all loose, falls down. How do I make that ball socket tighter?
Old Dec 31, 2001 | 01:33 PM
Flame Red's Avatar
Flame Red
Just a thought. I upgrade the mirror to one of those auto dim jobs with a built in compass. Very, Very :cool:
http://www.donnelly.com/products/int...ticcompass.asp
I installed one a couple of years ago that has just the auto dim, compass and courtosy lights built in.
Old Dec 31, 2001 | 01:50 PM
Hawaii89vette's Avatar
Hawaii89vette
Default Re: Rear View Mirror question.....sorta technical.... (Flame Red)
$200+ for a Rear View Mirror is crazy... Just to get a compass and temperature sensor in the mirror? I'd just get a new mirror cut and replace just the mirror.
-Tim
Old Dec 31, 2001 | 03:44 PM
Pete Clough's Avatar
Pete Clough
As much as I hate to recommend them, Pepboys used to carry replacement glass for mirrors. Not sure if they have your size but worth a try.
PC
Old Dec 31, 2001 | 05:32 PM
black86targa's Avatar
black86targa
Default Re: Rear View Mirror question.....sorta technical.... (Pete Clough)
I had a bad one too. took it out and had the glass shop put one of the little metal mounts on the glass. Then put in one of the late model GM electronic ones that dims by itself when lites hit it from behind. I got it out of a Caddy in the junkyard for $15. I love it. all you have to do is slip it on the mount and run a hot and a ground wire to it under the window trim.
Old Dec 31, 2001 | 05:51 PM
JonM's Avatar
JonM
I like the anti theft mirror on that page...It even calls the cops for you. :cool:
Old Jan 1, 2002 | 03:28 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Rear View Mirror question.....sorta technical.... (JonM)
The glass piece is pretty cheap. I got one from 18carfan through the mail, after I cracked my glass being too rough washing the car.
My '93 has heated mirrors - had to pop off the old glass, cut the wiring, and splice the new wiring to the old harness. The instructions come with the glass.
Hardest part was snapping the new glass back onto the trunnion without breaking the glass again.
Old Jan 1, 2002 | 01:29 PM
JonM's Avatar
JonM
You can also have the glass resilvered http://www.mirrorresilvering.com/index.html
To Rear View Mirror question.....sorta technical....
