Crossfire loosing fuel pressure
Old Aug 5, 2008 | 06:49 AM
Robs84c5's Avatar
Robs84c5
Default Crossfire loosing fuel pressure
My 84 crossfire has been stalling and cutting out for a while now and I wasnt quite sure where to start. Then I noticed that when I put a load on the engine that one of the throttle bodies doesnt appear to be spraying as much fuel as the other.
I put a fuel pressure gauge on it and found that at idle I have about 12-13psi of fuel pressure, when I put a load on the engine it drops to about 10psi. Other than the fuel pump is there anything else that would cause this. Also how do I get to the fuel pump on this car.
Old Aug 5, 2008 | 06:59 AM
JoBy's Avatar
JoBy
Bad fuel pump or clogged fuel filter.
Replacing the fuel pump is easy and you don't have to drain the tank.
http://www.joby.se/corvette/mods/2001-0X07_fuelpump/
You can install a TPI or LT1 fuel pump, they are better than the 1984 pump.
The fuel filter is bolted to the inside of the frame rail behind the right front wheel.
