LTX shootout
Old Aug 5, 2008 | 11:52 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default LTX shootout
I got to hit this next year
http://www.gmhightechperformance.com...age/index.html
Jeff Green swapped out his Opti in under two hours after the rotor pin let go to qualify, but was only able to coast to an 11.20 after the transmission let go-way off his best of 9.50 at 150 mph. Unknown to Jeff at the time, the cam pin had also sheared, which probably resulted in the wheelhop that broke the trans and bent the rear sway bar. If you're wondering, that's not silver paint on that block, it's a 446ci aluminum Donovan that's been welded and milled into the shape of an LT1 block, making 1,300 horses with the factory OBD-I PCM! Jeff has kept this 4,400-pound beast as stock as possible and even runs the original 10-bolt rear housing. We will go into detail on this amazing car in an upcoming feature.
Old Aug 6, 2008 | 08:33 AM
RacerX70CC's Avatar
RacerX70CC
Originally Posted by BrianCunningham
Saw that too... totally bad-a$$
Gotta love that fact somebody thinks the LTx platform isn't dead... that modified Donovan block alone probably cost more than the typical complete 383 forum engine
Old Aug 6, 2008 | 09:18 AM
89FX3's Avatar
89FX3
Default 1300 hp!
I notice Jeff Green's using a set of AFR heads in order to coax 1300 hp out of that Donovan engine...
Wonder which ones and what's been done to them...
I'm also surprised to see a fairly 'normal looking' throttle body setup...
Old Aug 6, 2008 | 10:21 AM
LT4POWR's Avatar
LT4POWR
Yea, I was planning to go to that one, but I (poor me ) had a conference in vegas during that time.
To LTX shootout
