Hard Starting 1990 L98
Old Aug 6, 2008 | 06:10 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Hard Starting 1990 L98
Here is the problem. When the car is hot, or has been sitting for some time it cranks for a while ( maybe 10 sec.) before starting. Long story short, this was happening every time I tried to start the car and I smelled fuel. I just replaced the injectors, thinking that was my problem, with Ford Racing Red Top 30 lb/hr ones and had the computer tuned. This greatly improved my gas milage, it doesnt take as long to start now, and I no longer smell fuel. However it still cranks for some time before starting. I hooked a fuel pressure gauge up to it not too sure what the proper procedure was for checking fuel pressure. I turned the key on, heard the pump come on, but the needle didnt move. I started the car and the gauge read a steady 38 psi. When I shut the car off I turned the key back to the on position and the gauge jumped to 44 psi and slowly dropped to 0. Do I have some sort of internal fuel leak or am I checking the pressure wrong? It has had a tune up around 1000 miles ago. Is this even a fuel issue??
Old Aug 6, 2008 | 07:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It sounds like you have a leak somewhere:
-injectors
-FPR
-FP
-lines
After you turn the key On the FP should run for ~2sec charging the line to around 44psi and this pressure should hold for at least a few minutes.
Old Aug 6, 2008 | 07:42 PM
cwyates4's Avatar
cwyates4
Follow this guide and you will find your problem:
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Aug 7, 2008 | 07:07 AM
Kubs's Avatar
Kubs
-injectors
-FPR
-FP
-lines
When I turn the key on the gauge does not move until I crank the engine over...
I just replaced the injectors thinking that was the roblem but it still does it.
Old Aug 7, 2008 | 07:12 AM
Kubs's Avatar
Kubs
Thanks! That looks great. I will try that.
Old Aug 7, 2008 | 11:04 AM
rick lambert's Avatar
rick lambert
Could be a few things, but I'm betting on the fuel pressure regulator, pull the vacumn line off it and see if it's wet (gas) if it is then you know what the problem is. I only think this because of the smell, if it were the fuel pump pulsator or check valve I doubt you'd be able to smell it. BTW, how old is the pump and filter?
Old Aug 7, 2008 | 01:18 PM
wro87's Avatar
wro87
ALso look around the FP gauge. We found that ours was leaking and it would smell when we shut it off took as a while until we could see it drip. When we tighten it up it started to pour/spray all over (lucky no fire), Found that the tupe from the rail to the gauge was just brass and it cracked. bought the repalcement fittings from Summit a real nice ANR fitting with the right connectors and an extra gauge. Good luck.
Good luck wro87
Old Aug 7, 2008 | 04:03 PM
Kubs's Avatar
Kubs
I dont know how old the pump/filter are. I have new filter I was planning on putting on but I think if it were a clogged filter the performance would be effected and its not. I bought the car with a salvage title from the junk yard after it was rear ended. The tank and pump were replaced but the parts came from another car so both are not new. So to check the regulator I just undo the vacuum line where it connects to the regulator and if its wet thats the problem??
As far as the gauge, its not a permanent one, I screw it on the fitting and lay it on the windshield while I play with the key. That wasnt leaking because there was no gas around it after checking the pressure.
To Hard Starting 1990 L98
