2.73 upgrade to ????????
Old Aug 7, 2008 | 10:02 PM
198T7VETTE's Avatar
198T7VETTE
Default 2.73 upgrade to ????????
I have the G92 with the 2.73's. What is the recommeded gear choice for a nearly stock car? Need much more low end power......
Old Aug 7, 2008 | 11:43 PM
rodj's Avatar
rodj
Old Aug 8, 2008 | 12:10 AM
AKS Racing's Avatar
AKS Racing
Originally Posted by rodj
3.07
For a nearly stock TPI, 3.07D36 is the ticket. If you had some mods (heads, cam, intake, exhaust), then I would highly recommend the 3.33D44.
Aaron
Old Aug 8, 2008 | 12:13 AM
Master__Shake_'s Avatar
Master__Shake_
Gears aren't going to give you more low end power. They're going to shorten the powerband, making the low-end disappear and replace it with the mid-range RPM. Then, if you have auto, you also need a good converter to make the most out of it. If you just want a little more fun, I don't suggest going higher than 3.45s because your gas mileage will drop horribly. That, and L98s don't like to rev higher than 5k.
If you want more power, swap in a better exhaust system. Throwing on a dual exhaust with LT headers and muffler elims will give you ~40hp to play with.
Old Aug 8, 2008 | 01:20 AM
vader86's Avatar
vader86
3.07 is an optimal ratio for L98 automatics, but since going to that from 2.73 is hardly worth the expense, I recommend changing your torque converter to one with a stall around 2200-2400RPM.
Would give you the feeling of more power at stop lights without cost of mileage.
Old Aug 8, 2008 | 09:17 AM
Demonic85's Avatar
Demonic85
Honestly, i'd keep what you already have unless your going to build up the engine to the point where you need a stronger rear end. Just my 2 cents.
Old Aug 8, 2008 | 09:59 AM
Kool88vette's Avatar
Kool88vette
I went from 2.73 to 3.07s. I really like the new gears.
With the 2.73 and OD I could cruise at 85 MPH all day and still get good mileage. I would shift into OD at about 65 MPH.
But, around town it felt sluggish. The 3.07s woke it up. Then I had a 2400 Vigilante installed. The difference is like night and day and I still get decent mileage.
Old Aug 8, 2008 | 01:15 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
IMO 2.73 to 3.07 is not worth the expense. Get a higher stall and do minor engine mods and open up the exhaust.
Old Aug 8, 2008 | 03:04 PM
198T7VETTE's Avatar
198T7VETTE
I do agree with everyone here. There is not much of a difference between the two. I was thinking of a gear ratio something in the mid three's but you guys all think differently. Mid three gears not right for a L98?
Old Aug 8, 2008 | 03:44 PM
vader86's Avatar
vader86
No, not for a stock or anywhere-near-stock L98. The powerband is too short for them.
To 2.73 upgrade to ????????
