My new stall will be here soon from Pete K. I want and probably need to install a external cooler for the transmission. Should I bypass the radiator or leave it in line? Thanks, -Mike
Big can of worms.Many previous debates
Some say run through stock cooler to get trans up to operating temp faster;
Others say run stand alone to prevent heat from radiator heating up trans fluid on the basis coolant has potential to be hotter than optimum temp for trans.
I've been doing some testing with it run through the radiator and without. I would like to test it more but so far I have found that it doesn't run much cooler. It does however heat up much faster at idle and get much hotter. At this point I recomend leaving it through the radiator. So far I've only seen 5° cooler at cruise without the radiator. I have found the trans to run cool at cruise and the heat issue to be at idle or slow speed, so I recomend a fan. I feel like I should have went bigger with the cooler, so buy a large one with a fan!
I was going to post the link to my install but a search won't pull it up. Is something going on with the forum?
I have searched.......before Tues Just wanted to see what the current consensus was. I can see where it would be a good debate. So I guess I'll ask this......heat sink cooler or air flow thru?
On a daily driven vehicle, the transcooler should be run in series with the stock radiator cooler.
I used a heat sink design transcooler because I didn't like how the flow through design transcoolers block the front of the AC condensor but, the flow through design transcoolers are more efficient. I just installed the heat sink transcooler in series for some added protection.
I run mine in a series. First through a Ron Davis radiator, then through a B&M supercooler mounted on the front of the condenser. I am waiting for Aardwolf to do some more testing to decide what to do. I have an Autometer trans. temp gauge sitting on my coffee table waiting to be installed, then maybe I can do some testing.
Unfortunately I am back to square one as I can't compare anymore, my trans burnt up. I have had it rebuilt but the temp sensor is now in the case instead of the pan. So I'll have to start over comparing things. I've also thrown on the used Derale cooling pan I got from Pete.
What was the failure due to? Hope it wasn't Oil cooler installation? and how many miles did you have on it?
120,000 on it and a previous owner had it rebuilt, we could tell by the parts once it was a part. The 3-4 burned up and the band, both weak points. The pan was all full of the gray material. I put the cooler on a year or two ago. I like to road race the car so the trans really takes a beating.
I would really be interested in before and after temps. You never really here the benefits based on numbers. We know a cooler is very important on the A4. I run mine with my BeCool radiator in line to my external. My laser guided temp reader says around 160-180 degrees. 2800 rpm Vigilante and 3.75 gears.
Thanks for all the input guys.
I'm surprised no one has put a simple cut off in line of one of these coolers to see the difference. I mean how could that be with the rubber hoses and all.
I used -6 AN Male to 5/ 16 in. Tube( part number EAR-165056ERL) and -6 AN Hose to Female -6 AN(part number EAR-800106ERL).
So to use the EAR-165056ERL, you cut the end of the tubing off? Did you connect both lines to the trans cooler lines, eliminating the radiator cooler?
Thanks, Bruce
Thanks, Bruce
Yup, I cut the end of the tub off on both lines and attached that fitting to it. The radiator is no longer in the loop.
