Wheel Offset question
Old Aug 8, 2008 | 11:40 AM
Doug 87L98's Avatar
Doug 87L98
Default Wheel Offset question
I KNOW, I KNOW !!!!! Use the search function!
I did, but it is not working. I found a number of threads that would probably answer my question, but I am unable to open them.
Would a pair of 94 9.5" sawblades with 275-40-17 tires fit on my 87 Vette with out any issues?
Old Aug 8, 2008 | 01:00 PM
MickeW's Avatar
MickeW
Hi,
I think you will need spacers, but don't know the size.
Aprox 20mm.
Regards
MickeW
Old Aug 8, 2008 | 01:21 PM
vader86's Avatar
vader86
You dont even have to use the search, its in the FAQ.
Old Aug 8, 2008 | 04:23 PM
Doug 87L98's Avatar
Doug 87L98
That's not working either!!!
Any body know for sure?
Old Aug 8, 2008 | 04:28 PM
MickeW's Avatar
MickeW
FAQ working great
http://forums.corvetteforum.com/showthread.php?t=956100
regards
MickeW
Old Aug 8, 2008 | 05:11 PM
vader86's Avatar
vader86
It works just fine. Click it again.
Old Aug 8, 2008 | 05:13 PM
Doug 87L98's Avatar
Doug 87L98
Thanks for posting that MikeW.
I can't get either function to work from the computer that I'm on now.
Old Aug 8, 2008 | 05:43 PM
c4cruiser's Avatar
c4cruiser
84-87 wheels had a 38mm offset, 88 and later had a 56mm offset.
That's a difference of 18mm or 3/4".
the tires will work fine as the overall width and diameter are very close to the OEM 255/50-16 tires.
Old Aug 8, 2008 | 07:53 PM
Doug 87L98's Avatar
Doug 87L98
Thanks for the info. I'm picking up a set of drag radials on sawblade rims at a pretty good price.
Old Aug 8, 2008 | 09:27 PM
c4cruiser's Avatar
c4cruiser
Actually for the rear wheels, you may not need any adapters at all. If the tire will fit in the wheelwell and doesn't hit any of the suspension pieces, you will be OK just bolting the wheels on. Also check the flexible brake lines to make sure they will clear the tire.
To Wheel Offset question
