92 c4 drivers side plug wires
Old Aug 8, 2008 | 01:17 PM
bee674's Avatar
bee674
Default 92 c4 drivers side plug wires
Is there a way to remove drivers side plug wires from opti dist. with out removing a/c comp, alt.,ps pump? Any hints or help with "how to" would be great, or is that the only way? I have plugs replaced but was stopped by this difficult looking, minor task.Thanks
Old Aug 8, 2008 | 01:26 PM
94z07fx3's Avatar
94z07fx3
If you don't want to remove the brackets in the way consider removing the boots off the plug end of your new wires.
Old Aug 8, 2008 | 01:49 PM
bee674's Avatar
bee674
Thats a good idea for routing wires, but also can only touch ends of old wires on opti,cannot get grip to remove or replace. Is there any acess from under car? Or is only option to remove said accessories? Thanks
Old Aug 8, 2008 | 01:59 PM
schrade's Avatar
schrade
Several pics of necessary access stuff here:
http://forums.corvetteforum.com/show....php?t=2069247
Old Aug 8, 2008 | 02:04 PM
94z07fx3's Avatar
94z07fx3
Oh! as for that, with the belt off the tensioner pulley moves itself out of the way.
Old Aug 8, 2008 | 05:56 PM
skybolt31's Avatar
skybolt31
I did this when I did my water pump and opt, so some things were removed anyway, but I would say to remove the belt and tensioner, that is just one bolt and also the power steering pump pulley. You will need to loosen the ps pump to feed the wires in between the pump and a bracket. I don't think you need to remove anything else. It is a pain to run the wires under there no matter what you do, just take your time, make notes before you take any wires out, label all the new wires and oh yeah, take your time.
To 92 c4 drivers side plug wires
