Mini Ram and MAF
Old Aug 8, 2008 | 11:37 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Mini Ram and MAF
You guys with a MR and MAF, how did you deal with MAF and a MR...did you have to go to Speed Density?
I would think not.
Wiat, it's late, it's the other way around....isn't it?
Old Aug 8, 2008 | 11:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Vic'89 is running a MR and I think he still have the MAF.
Old Aug 8, 2008 | 11:43 PM
cwyates4's Avatar
cwyates4
I have a mini with MAF, it ain't goin' so well right now though!
It will work just fine though.
Old Aug 8, 2008 | 11:53 PM
jsup's Avatar
jsup
Wait, 90 has speed density.....I'm an idiot...
I can't function at midnight after a few beers.
Effects my clarity.
Old Aug 8, 2008 | 11:58 PM
cwyates4's Avatar
cwyates4
Go to bed!
You need some
Old Aug 9, 2008 | 08:21 AM
88BlackZ-51's Avatar
88BlackZ-51
Have you decided how this beast will be tuned?
Old Aug 9, 2008 | 08:24 AM
jsup's Avatar
jsup
Yeah, Alvin PCMFORLESS.
Then I'll run some logs.
Then I'll have it tweaked.
Then I'll fine tune it with a dyno tune.
Alvin already did my chip and makes adjustments at no charge. So I'm going to have him get me "close enough" and go from there once the logs are done.
I am sure you're going to tell me I'm completely wrong because I didn't use your guy and do it your way, so I'm ready....so go.
Old Aug 9, 2008 | 08:28 AM
88BlackZ-51
The only thing I was going to say is man, you are a posting ****, and I might add super fast at replying.
My guy is myself, and the F.A.S.T. system I purchased.
Old Aug 9, 2008 | 09:47 AM
jsup's Avatar
jsup
Then this is where you tell me I should be going for a F.A.S.T system and I'm leaving power on the table....blah blah blah....
Old Aug 9, 2008 | 10:18 AM
88BlackZ-51
You are negative.
Old Aug 9, 2008 | 11:43 AM
-=Jeff=-'s Avatar
-=Jeff=-
I would use a DynamicEFI ECM set-up for 8 injectors. Ditch the MAF for MAP, retain ALL cluster functions, have the ability to FLASH program, autotune, ETC. my friend was a beta tester for this. very COOL set-up simple and still uses OEM ECM hardware. Few harness changes and your good to go..
Pm or email me for a link as I do NOT want to break forums rules
OOPs, just realized your is a 1990.. this syste, is better for 89 older.. LOL
To Mini Ram and MAF
