HELP! Grinding sound in windows
Old Dec 31, 2001 | 08:50 PM
IcemanZ06's Avatar
IcemanZ06
Default HELP! Grinding sound in windows
There is a grinding sound in both windows when I put them down. It seems to always occur in the same for each window so I don't think its the window motor. It sounds like the window is rubbing up against the inside of the door panel. How do I fix this?
Old Dec 31, 2001 | 10:09 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: HELP! Grinding sound in windows (IcemanZ06)
Remove the door panel and determine the cause of the rubbing/noise. Then correct the problem. The guides may be loose.
Old Jan 1, 2002 | 12:11 AM
SLOWBUSA's Avatar
SLOWBUSA
Just be happy your windows work. :mad :bs :yesnod:
To HELP! Grinding sound in windows
