educate me on coilovers
Old Aug 10, 2008 | 02:23 PM
Jim D's Avatar
Jim D
Default educate me on coilovers
Do coilovers replace the springs. I was told they would improve the ride on my 87. What can I expect to pay for coilovers, thanks Jim.
Old Aug 10, 2008 | 02:50 PM
1989vette's Avatar
1989vette
Well jim, they do replace the mono leaf spring. With the coilover you are replacing the shock aswell as adding a spring that goes around the shock. They can improve the quality of the ride, but you have to get a mild spring and adjust the rebound of the shock for them to be smooth. I have Qa1 coilovers and I have a 450lb spring and it rides smooth but it is a hard ride, but it sure keeps the wheels on the ground. You can also expect to pay $500 for the coilovers, then you have to buy the sway bar mounts if you use a wider spring.
Old Aug 10, 2008 | 02:58 PM
StealthLT4's Avatar
StealthLT4
Don't go coilovers just to get a smooth ride. That will be a very expensive smooth ride. The primary benefit (and the only one worth the cost IMHO) is for track use where you can customize each spring rate and ride height for each corner of the car.
If I remember correctly, expect about $500 just for front coilovers using QA1's, and the rear is more difficult. Both DRM and EM sell kits for upwards of $1,000 for all 4 corners.
Old Aug 10, 2008 | 03:02 PM
FAUXGS's Avatar
FAUXGS
Default coilover
Please explain 'then you have to buy the sway bar mounts if you use a wider spring'. I have recently purchased a used set of Bilstein coilovers and I'm trying to anticipate installation issues.
Old Aug 10, 2008 | 09:05 PM
LD85's Avatar
LD85
For your model year, @ $1300 for the Exotic Muscle plug n play setup with a Heim for your front sway bar.
QA1's wont fit the front shock towers safely, but the rears can be made to work if you cut the upper rear bracket's off and got to the stud or reweld the bracket back on.
Benefits are adjustable ride height and soft or stiff ride, I love mine and I do not road race,
I use a 400 front and a 275 rear
see sig.
Old Aug 11, 2008 | 01:55 PM
1989vette's Avatar
1989vette
I am not to sure about Bilstein coilovers, but with the Qa1, the sway bar has to be moved out 3/4 of an inch so it does not contact the spring. This is done with an aluminum spacer between the control arm and with a heim joint. Exotic Muscle sells this kit, but it is pricey.
To educate me on coilovers
