Yesterday while I was pushing my car back to the house, I noticed something on the ground where my rear end finally let go. Its a rubber ring of some sort, I think it came from my car, but what is it? Where could it have come from?
Looks like the gasket for the blinker fluid reservoir. Good thing you found it, those things are expensive and RARE.
It may not be from your car but if I had to guess it looks like it could be from some type of clamp, though I don't know if they would use rubber like that on your exhaust.
Man, glad I found that!
I think it did come from mine. Not many cars around here, and it was warm and wet with a lil' oil when I found it; came from the same spot the rear went bang (I only got half a block from home! ). Maybe some type of seal from the rear end; I wonder if I put a hole through the diff. housing somehow...
Hopefully not, but I'll admit I've never rebuilt the D44 in mine (knock on wood) but it very well could be. The fact that it was covered with a little oil and warm certainly narrows down your potential sources.
