tuning for better mileage
You mean like That?
Sure. Why wouldn't you? There's a couple of MPG, on average, in there from what might be considered a "better" performance tune - mostly in where the BLM's end up.
BTW - running higher octane gas (93 as opposed to 87) means a bit more timing in there most of the time which results in another mpg or so, average. For the .20 per gallon difference at the pump it's worth it..
Also - taking the 255's off and putting the 225/65-16 snow tires On gets me another 1-2 mpg. At least it does until the gas stations around here start pumping the "winter" blended stuff, and the numbers go back Down until spring.
ECM program. It was not EPA-approved, so it was not activated in US cars.
However the code is there, and just needs to be turned on and dialed-in.
I don't recall what masks have it, but it's in the $8D code for sure. Read
about it over on the TGO DIY board. It's meant to improve trip mileage
safely - from the engine's perspective.
As for the rest, GM's stock program was built to make the best EPA mileage/
drivability they could in production car form. Unless you're smarter about
the engine than GM, you should take internet 'tuning' ideas with a grain
(or more) of salt. It's easy to damage the eng, trans, or cats with
haphazard program changes.
JMHO
It's in the 1985 $1F, also, BTW...
I Have tried messing with it in My car. I've set the threshold parameters so that it should activate, and I Think I can see it happen in the datalogging (I can't see the timing advance being commanded, which is the Main thing that highway mode changes..). I did NOT see any measurable gain in fuel mileage. That doesn't mean there isn't something to be "found" there, however...
Another way is with the Zeitronic wide band O2 meter you can change the switch point of the narrow band output from 14.7 to something leaner.
You may want to look at the Smart Car if you want better gas milage.
And,
Like the infamous quote from (Barack Obama),
(Air up your tires), Like 60 0r possibly 70#s.
Just think, if we all did this, people like the Kennedy's
wouldn't have to look out over the ocean with their telescopes
and see those wind turbines and oil platforms.
Uh Oh, my bad, wrong forum.
Although this is a milage thread,Rite?
Later
