HELP! No oil pressure on LT1
Old Jan 1, 2002 | 12:25 PM
Colorado Chuck's Avatar
Colorado Chuck
Default HELP! No oil pressure on LT1
My '95 LT1 starts, runs fine, but shows no oil pressure. Oil and filter changed, no change. My '96 manual says the oil pressure sending unit is also a fuel pump switch. Would this mean the fuel pump would shut down if there was no oil pressure? Where on the engine is the sending unit located? I could go look but it's bitter cold in the garage. If the sending unit tests ok, what is the next step?
Old Jan 1, 2002 | 12:46 PM
CAPN17's Avatar
CAPN17
Default Re: HELP! No oil pressure on LT1 (Colorado Chuck)
Your guess is correct there is a saftey that prevents the fuel pump from remaining on if there is no oil pressure after start. You may have a bad sensor for the dash guage or the gauge it self may be bad.
Old Jan 1, 2002 | 12:49 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Yes I agree new sensor is in order.
Old Jan 1, 2002 | 04:56 PM
Red Dwarf's Avatar
Red Dwarf
C/C,
The sending unit is located at the top rear of the engine. Its a Tee fitting.
The oil pressure sending unit is on the passenger side. You might want to check for pressure with a mechanical gauge. You might try wiggling the wires, you never know?
:cheers:
Old Jan 1, 2002 | 06:09 PM
Eric Fischer's Avatar
Eric Fischer
Default Re: HELP! No oil pressure on LT1 (CAPN17)
You sure about that? I thought that there was a oil pressure switch mounted in parallel to the fuel pump relay that allows the fuel pump to run as long as there is oil pressure (in the event that the relay fails).
Old Jan 1, 2002 | 07:10 PM
Colorado Chuck
Default Re: HELP! No oil pressure on LT1 (lou sylvestri)
Thanks, Lou. Maybe now I can find it before I freeze to death! We are not having weather good for either driving or working on Corvettes.
Old Jan 2, 2002 | 12:17 AM
Red Dwarf's Avatar
Red Dwarf
Default Re: HELP! No oil pressure on LT1 (Eric Fischer)
There are two sensors located in the Tee.
One is for the oil pressure & one is for the oil pressure sensor/pump switch. This is for an LT1. :cheers:
Old Jan 2, 2002 | 01:47 AM
vanduker's Avatar
vanduker
I believe Eric is correct. The "fuel pump" portion keeps the pump running if there is oil pressure but it does not cut the pump off if there is no pressure.
As the others have said - time for a new sensor.
Mark
Old Jan 2, 2002 | 07:12 PM
Colorado Chuck
As soon as I located the sender and touched it, I knew that was the problem. Whoever put it in, broke it trying to get the socket on or off. It is a real PITA to replace, but I now show pressure. With the old sender removed, I packed rags around the tee and started the engine, which ran fine for at least the 3 or 4 seconds before I shut it off. I wanted to be sure the oil passage was clear, and to check the "fuel pump shutoff" theory. I don't think the oil pressure sender affects the fuel pump, but perhaps that is what the other switch on the tee is for.
QUESTION: When I fastened the electrical connector back on the sender, I heard a sound like a small motor running, even though the ignition was off. I started the engine, shut it off, and the sound continued for several seconds more, then shut down. What was that, and what does it do?
Thanks again for all the help. :)
Old Jan 2, 2002 | 09:36 PM
stingraymarc's Avatar
stingraymarc
Chuck,
I follow your thread with great interest as my LT1 has a similar prob, except it shows max pressure all the time. How the heck did you get that thing removed? did you use pliars, special tool, etc?
Marc
Old Jan 2, 2002 | 10:57 PM
mash557's Avatar
mash557
Chuck, was the key on when you plugged up the sender? If so, the air pump for the AIR system may be running. Try and isolate where the noise is coming from. Just noticed that you were working on a 95 from a 96 manual. I just finished reading the tome Corvette Fuel Injection which covered the systems intricately from 82 to 01 and the 95 is a psuedo OBDII car and the 96 is the real deal. As such certain things function differently. That said, I believe it said that the electric air pump would run for 240 seconds when the Engine coolant temp was 60 degrees C. or below. Good Luck
[Modified by mash557, 9:01 PM 1/2/2002]
Old Jan 2, 2002 | 11:59 PM
Colorado Chuck
Default Re: HELP! No oil pressure on LT1 (mash557)
Marc, I bought a special socket from the NAPA parts store. Problem is, there is no room to get it on and no doubt that is why the old sender was broke. I found that I could rotate the back end of the tee where the sender screws in towards the passenger side, which gave me room to get the socket on. I then had to push it back in order to attach the electrical connector which was another PITA. To remove and tighten the sender I used a wobble extension, which has rounded ends where it goes into the socket allowing you to be well off center. I have an old jeep where the oil pressure pegs itself, and I am sure it is because I have the wrong sender installed. Be sure you get the correct one for your car.
And if there is anything that requires maintenance, it is a helicopter! Fly one hour, work 10!
The ignition was turned OFF when I heard the motor noise. It continued with the ignition on and finally turned itself off. It just really surprised me to hear a motor come on when I plugged the sender in. The sender is a 3 prong switch, which I and others thought was for the fuel pump.
To HELP! No oil pressure on LT1
