injector videos and questions
#41
there is one way
and you won't regret
Call Jon at www.fuelinjectorconnection.com
770 888 1662
#43
Thank you very much for taking the time and explaining as well as demonstrating everything. Again, My thanks and respect to those here whocontribute their time and expertise.
This saved me mucho dinero. well it will when i can save up for a new set.
cheers
Ronnie
1988 vette
cheers
Ronnie
1988 vette
#44
I have an 84 that is hard to start, I have to crank forever.
Could this be the injectors and can I send them to you for a complete rebuild?
I watched your video and I know now that I do not posses the skill to rebuild and test the injectors. Do yo also do the regulators?
#45
Supporting Vendor
#46
Hi Jon, Do you have the store on ebay.I think I found your store just not sure. I have a set of 24lb accel injectors in my 90 vette but ever since I installed them I get a code32 (egr problem ). I have tryed about everything to fix the problem ( see my EGR code 32 problem thread ). I think that maybe since I have installed these injectors it might be leaving a little fuel (dropplets)in the intake and setting the code I am getting. I like the way the Bosch III spray pattern looks and hope this might help me with this problem. The original injectors I believe were the multec design and after alot of troubleshooting ( resistense problems from about 8 - 16 ) found out they were the problem with my vette running bad. That is when I purchased a set of these accel pencil spray type injectors. Again, I didnt have a code32 problem until I installed these injectors. Have you ever heard of anyone having a simular problem like this.
#47
Supporting Vendor
#49
was there ever a solution to the problem of high BLM's after an injector intall ??
This was with any brand, my particular experience was with Accel. Other's have experienced it with other brands as well.
#50
St. Jude Donor '03 & '05
Please dont flame, please read
I know this sounds skeptical, but how much of the change in our tests were really due to just having new injectors put in? Mileage, age, cleanliness play a big part.
Everyone claims seat of the pants, but where are the dyno numbers to back it up.
I know the Bosch III's are better, but they are new.
I would love to see a dyno test, engine dyno, where New GM injectors for a random COrvette (L98,LT1) was run, then brand new Bosch III's installed. That is more realistic.
#51
Supporting Vendor
#52
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
ZR-1 / LT5 injectors
I know I probably missed the answer to this Q on your web site....:o
The set of LT5/ZR-1 injectors that you sell ( not the NCRS injectors ) as replacements for the 90 - 92 ZR-1's are which Bosch design?
Thanks!
Tom
Thanks!
Tom
#53
Supporting Vendor
Tom they are Bosch 2.. They have the same 4 hole discharge as the Bosch 3 and are compatible with e-10.. The bosch 3 will not fit in the 90-92 Z
#54
ZZ4 with MiniRam
Jon,
Here's my engine in my 64 Vette:
ZZ4, bored to 353 ci
Heads are L98 style, mild porting
Stock Cam
TPIS MiniRam with OBD1
Dyno Tuned 4k miles ago.
I think the FI's I'm using are off my prior motor which was a 98 5.7 L TPI (Slightly Modified).
What injectors do you suggest, and will I need a new tune?
Stock Cam
#55
I was liking the atomization vid of the Bosch III's and wanted an injector that would be better than the Lucas based replacement injectors' atomization that I now have on the motor. I was kind of surprised at your demonstration of the spray patterns. The Lucas pattern was not all that pretty to look at!
#56
Supporting Vendor
Jon,
Stock Cam
Stock Cam
http://fuelinjectorconnection.com/sh...&productId=166
JON
#57
How can I verify that they are 24's? When the shop built my previous engine, they may have changed the size and went larger. It was not a stock L98. HP @ FW was at least 350 HP.
My new engine dyno'd @ 408 hp with a carb/intake setup, but it's now running the MR with my old injectors.
#58
Supporting Vendor
how can i verify that they are 24's? When the shop built my previous engine, they may have changed the size and went larger. It was not a stock l98. Hp @ fw was at least 350 hp.
My new engine dyno'd @ 408 hp with a carb/intake setup, but it's now running the mr with my old injectors.
#59
Jon if you have time can you answer a few questions ?
1 Whats the maximum fuel pressure I can use for Bosch 3s ?
2 Whats the max duty cycle I can run for short periods, maybe 3 seconds at the end of a 1/4 mile run ?
3 Are they E 85 compatible ?
Thanks. I guess you can see what my plan is.
#60
Supporting Vendor
I DON'T LIKE TO GO OVER 93ds
THEY ARE 100% COMPLIANT TO ALL FUELS INCLUDING METH
