Heated O2 sensor question, repeated failure
Old Aug 13, 2008 | 03:21 PM
billvh's Avatar
billvh
Default Heated O2 sensor question, repeated failure
I have a 90 L98, and have installed a heated O2 sensor for a 95 Astro in header flange. Is this sensor OK? It is a Bosch, and this is the third time I have replaced it in a year or so. I'm getting a code 44, it's rich and running bad when in closed loop. I haven't changed it yet, before when it was bad, the car would backfire constantly through the exhaust, and replacing it cured it for a while. What would cause it to go bad?
