Help! LT1 cooling system problem!!!!!
Old Aug 13, 2008 | 09:51 PM
tcr75's Avatar
tcr75
Default Help! LT1 cooling system problem!!!!!
This may be a bit long so please be patient with me. Just about a week and a half ago I noticed that my coolant temp guage in the digital cluster was reading fine and my analog one was way off. I took it to a mechanic that I know he said that it was the sensor but to go ahead and change the thermostat and flush the system since the coolant looked a bit old. I drove after and noticed coolant loss. I kept my eye on the colant level for a few days. It did get too hot, just shy of 250. I thought I may have developed a bad head gasket. There was no water in oil or oil in water. When I reved the engine and quickly let off the throttle with the radiator cap off it did not geyser so I felt the head gasket was fine. Engine ran as great as ever. I finally noticed the water pump leaking a bit at idle. That was the source of the magically disappearing Yesterday I changed it and the Opti since I was that far in. I could not get 4 gallons in the system at all even after running it to where the thermostat opened up. I tried to bleed the air out. I filled it until coolant came out of the bleeder then closed the bleeder, ran the car for a couple of minutes, shut it off and opened the bleeder again. I did this several times until only coolant came out. It never even reached 200 dergrees the whole time doing this. I took it for a drive and it seemed great for the first ten or fuiften minutes. Now the mystery issue. It started getting hot, around 238-240. Then all of a sudden the low coolant light would come on the the car would rapidly cool off to around 210-215 and be fine. Ten minuted later the same thing happened. I drove home, let it cool and checked for air again, lots of air. Filled up with coolant, checked half a dozen times, went for a drive with no problem. Today I went a few miles through town to auto zone to get a can of 134a. I had the car running in the parking lot filing it with the 134a and it was getting hot again, hit 241. I got it and started driving home and the low coolant light can on and it cooled of to 212 rapidly. I got home and checked the system, more air. I am frustrated beyond belief with it. Is there a trick to filling the cooling system? Maybe another issue? I also posted wondering the hose routing, perhaps the hoses were put on wrong when the system was cleaned and flushed before the water pump was replaced. Or maybe I screwed up putting the hoses on the pump after I replaced it.
Old Aug 14, 2008 | 01:25 AM
wb2dyb's Avatar
wb2dyb
Just a thought...is your coolant recovery tank hooked up...and liquid in it?
-Georgec
Old Aug 14, 2008 | 02:01 AM
tcr75's Avatar
tcr75
yes. I just figured out that I have a blown head gasket.
Old Aug 14, 2008 | 09:12 AM
aminnich's Avatar
aminnich
You have to bleed it with the engine running and at op temp so the stat is open or you will never get all the air out. 92-94 have two bleed screws, 95-96 only one bleeder.
How did you figure out a bad head gasket?
Old Aug 14, 2008 | 02:43 PM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
Tony, how did you determine that you have a head gasket leak ???? If you do, DO NOT replace gaskets until you determine the SIZE of the leak. Sealants can work wonders if used appropriately.
read my recent post 7 pages.
http://forums.corvetteforum.com/show...ght=read+posts
I posted a suggestion on Alberts thread earlier before i saw your thread.
Joe
To Help! LT1 cooling system problem!!!!!
