I have a 1990 Z51 with the big brake package. I am very slowing acquiring parts (as the budget will allow) for a C5 upgrade in the front. I was thinking of moving the current C4 front calipers to the rear. Would this be too much rear brake?? Has anyone tried this before?
You probably could move the front calipers to the rear but it would require a custom caliper mounting bracket or some sort of adapter. The size of the pads used in thefront would be too big for the rear rotors so you would need a larger rotor. The size and offset of the rotor hat is different between front and rear (13" J55 fronts and 12" rear) which mandates the adapter bracket.
There would be no provision for a parking brake; the existing rear caliper has the arm for the parking brake cable.
The C4 rear disc is almost the same diameter as the C5 rear disc and the swept area (the total amount of rotor surface the pad rides on) is about the same.
Go with a good performance pad on the rear and get a stiffer brake bias spring to provide a little more braking effort from the rears. Doug Rippie has the C4 spring and the spring doesn't cost a lot of money.
Thanks. I am willing to make my own adapter brackets. I made aluminum 2 piston calipers from a GMC Envoy work on a 3rd gen Camaro so no problem there. I was just wondering if it would be too much brake force in the rear.
So you say to go with C5 rotors?? Are they thicker to help out with the added force? Would it be better to try and fit a 12" front rotor back there??
As far as the parking brake I don't need one. I do drive this car on the street but I am setting it up for road racing also.
A lot of work for no benefit. There is ample braking force and heat capacity in the C4 rears for racing. It will probably compromise the master cylinder, pedal travel and bias. Good luck.
When racing now after only a couple laps my brake pedal feels like mush. I know the C5 fronts will dissipate heat better but are you sure the rears arent contributing?
Based on my experience of the last 4 years and thirty+ events including Laguna Seca(which is the toughest on brakes) in my 3600#(fuel and driver LT1) the rears are not your problem. A bias spring and race pads are all you need for the rear. Rear rotors will last years and almost never crack(a sign of overheating) and the surface temp pyrometer readings I get are relatively low. Focus on the fronts and proper bias.
Do you have any air ducting to the frnt brakes? Getting cool air to the rotors or calipers will help a bunch. What fluid do you use?
If I wanted to stick with 12" rotors in the rear, are the non Z51 12" front rotors also 28mm thick??
FYI;
only the J55 13" rotors are 28mm thick.All rears and 12" fronts are 20.5mm
To put a twin pot caliper on the rear you would use a regular 12" front caliper
I am working on mocking one up. I currently use the Valvoline DOT 4 stuff. Its good to something like 480 degrees. Its the only thing I can find in part stores.
