92 LT1,no-sieze on spark plug threads????
Old Aug 15, 2008 | 04:09 PM
bee674's Avatar
bee674
Default 92 LT1,no-sieze on spark plug threads????
Used no-sieze grease on plug threads, is this recommended by GM since heads are aluminum? Any thoughts if its good or bad idea? Thanks
Old Aug 15, 2008 | 05:09 PM
makn u shiver's Avatar
makn u shiver
good idea ,thats they way to do it
Old Aug 16, 2008 | 01:10 PM
Klondike's Avatar
Klondike
I'd say mandatory. The steel in the plug will have an electron flow reaction with the aluminum and corrode themselves to the head. Without the anti seize, the aluminum threads will come out with the plugs when you try to remove them in a few years.
Old Aug 21, 2008 | 12:41 AM
mvitacco's Avatar
mvitacco
Old mechanic taught me anything that touches alluminum should
have anti-seize, else you run the risk of galling the threads. Just use
a little dab and be carefull not to get any on the electrode.
Old Sep 4, 2008 | 02:06 PM
BobRR3's Avatar
BobRR3
PS: Just make sure you don't try to remove the spark plugs with the engine hot.
Old Sep 5, 2008 | 04:55 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
FWIW, there are antiseize compounds that can be damaging to aluminum. make sure you get one that is 'aluminum safe'
Bill
Old Oct 16, 2008 | 10:48 PM
larry00's Avatar
larry00
While we are at it on waterpump bolts what is the best thing to use and how much of the thread do you cover.
I hear different stuff from different people.
Old Oct 17, 2008 | 07:27 AM
Mutt Vette's Avatar
Mutt Vette
Anti-seize on sparkplug threads has pros and cons.
Too much or sloppily applied runs the risk of the compound entering the combustion chamber and out the exhaust, fouling the O2 sensor. There's a quick $50 down the drain.
Not using anti-seize will not result in thread damage. Usually thread damage is caused by overtorqueing the plugs. Torque specs for plugs installed in aluminum heads are in the range of 20-22 INCH pounds. If you do not use a torque wrench, tighten spark plug finger tight, then tighten no more than 1/16th of a turn with a wrench.
Gorilla tactics will guarantee thread problems, with or without anti-sieze compound.
To 92 LT1,no-sieze on spark plug threads????
