coolant bypass
Old Aug 16, 2008 | 01:34 PM
Robl3870's Avatar
Robl3870
Default coolant bypass
does anyone have a picture of the coolant bypass done on there lt1
as the directions said i took off the left and right hoses under the throttle body .but there both 3/8 hoses the kit comes with a fitting that is 5/8 on one side and 3/8 on the other? am i missing something here. maybe i pulled off the wrong hoes? any help is appreciated.
Old Aug 16, 2008 | 02:25 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Check your other post.
MK 82's Avatar
MK 82
See your dupe post in General.
Old Aug 16, 2008 | 02:40 PM
MikeC4's Avatar
MikeC4
Coolant Hoses Required for 1993 LT-1 w/ TB Bypass Arrangement
Lower Radiator Hose – Standard 1993 hose. Routes from the lower radiator to thermostat housing.
Upper Radiator Hose – 1995 LT hose. Eliminates ‘Tee’ to TB. Routes from the upper radiator to the water pump housing.
Heater Hose – Standard 1993 hose. Upper surge tank outlet to upper heater core inlet at firewall.
Heater Hose – 1995 LT hose. Routes from the lower surge tank connection to the upper water pump housing.
Heater Hose – Standard 1993 hose. Routes from the heater flow control valve to the lower water pump housing.
Heater Hose – Standard 1993 hose. Routes from the lower heater core inlet to the heater flow control valve.
To coolant bypass
