Aux fuse panel
Old Aug 16, 2008 | 10:46 PM
jm22876's Avatar
jm22876
Default Aux fuse panel
Does anybody know where the fuse is located for the cigarette lighter on a 92. I looked under the passenger side knee bolster and found 1 of the aux fuse panels but from what ive read there are 3 in the 92. The main one and 2 aux fuse panels under the passenger side knee bolster. i can only find the one with the theft, door locks, fp2 and 1 conv. My cigarette lighter does not have power going to it (checked with multimeter) and I cant find the fuse for it.
I also read there could be one next to the battery. But I pulled the battery out to make sure about an hour ago with no luck
any help GREATLY appreciated!!!
ive been trying to fix this for a month with no luck
Old Aug 17, 2008 | 12:33 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
I don't know about the location, but the lighter circuit may be marked "Courtesy Lights" or "Interior/Dome".
Old Aug 17, 2008 | 09:21 PM
jm22876's Avatar
jm22876
Default the courtesy fuse was replaced
The courtesy fuse is supposed to use a 15 but the previous owner put a 30 in it. I replaced the 30 with a 15. The courtesy lights have always worked since i've had the car (only 9 weeks). I wonder if that caused damage, as in the fuse didn't pop when the lighter had a problem because of too big a fuse. Ive got to order my FSM so I can trace it because i have no power going to it.
To Aux fuse panel
