Gear help
Old Aug 17, 2008 | 06:32 PM
snowmanmdp's Avatar
snowmanmdp
Default Gear help
I'm trying to figure out what size gear i have At 80mph it's turning 1,800rpms....It's an 85 with a 700R trans:o Anyone do the math or tell me the formula for doing it?:o
Old Aug 17, 2008 | 06:33 PM
cwyates4's Avatar
cwyates4
Give me your tire size and I'll run if for ya'.
Old Aug 17, 2008 | 06:36 PM
cwyates4's Avatar
cwyates4
btw, here is the calculator I use:
http://www.f-body.org/gears/
gear ratios for the 700r4 are 3.06/1.63/1.00/.70
I bet you have 2.73s in the back.
Old Aug 17, 2008 | 06:44 PM
pologreen1's Avatar
pologreen1
well I see you have bigger rims than stock so that throws off the calculation on speedo, but I have 2.59's in a 1900 auto and I am like 1800 at 70 with stock 17'' rims and stock speedo gear. I think you probly have the same but the bigger rims throws off speedo a bit IMHO not sure if speedo gear was changed or anything else!
Old Aug 17, 2008 | 07:20 PM
CFI-EFI's Avatar
CFI-EFI
With an automatic your ring gear is 7.875" in diameter.
RACE ON!!!
Old Aug 17, 2008 | 07:49 PM
JackDidley's Avatar
JackDidley
RACE ON!!!
Ya, think ??? I'm betting he was looking for a different answer.
Old Aug 17, 2008 | 08:07 PM
snowmanmdp's Avatar
snowmanmdp
Originally Posted by cwyates4
give me your tire size and i'll run if for ya'.
315/35/17
Old Aug 17, 2008 | 08:14 PM
snowmanmdp's Avatar
snowmanmdp
RACE ON!!!
Unless it started life as a manual
Old Aug 17, 2008 | 09:41 PM
cwyates4's Avatar
cwyates4
How sure of you one the 80 at 1800rpms...your speedo or tach may be a little off. The best fit for that senario is 2.59s, which to my knowledge, were not available in 85s, only 2.73 or 3.07.
Have someone with a normal car unmoddified car pace you at 70 and see how much the speedo is off.
Old Aug 18, 2008 | 12:11 PM
snowmanmdp's Avatar
snowmanmdp
I'll give you that one or the other or both could be off! All I was looking for was is it a 3.07...I was pretty sure it was not!!! It is never in the powerband when driving it! All I do is drive it around town when it's nice and I need to get out....So I'm wondering with a new intake,roller rockers and Vortec heads what gears you think would work best? I think 4.10 but I think I'm the only one
P.S. The rearend was rebuilt about 2 years ago but I see nothing about changing out the gears.
Old Aug 18, 2008 | 12:20 PM
vader86's Avatar
vader86
Sounds like 2.59 to me.
Old Aug 18, 2008 | 12:46 PM
cwyates4's Avatar
cwyates4
No 2.59s in the '85. Its either 2.73 or 3.07.
OP: look for G92 on your RPO list, if its there, you have 3.07. If not, 2.73s.
Old Aug 18, 2008 | 06:31 PM
snowmanmdp's Avatar
snowmanmdp
HUH? RPO I have no idea what you are talking about!
Old Aug 18, 2008 | 06:36 PM
MK 82's Avatar
MK 82
RACE ON!!!
The rumors of your death were apparently premature.
Old Aug 18, 2008 | 06:37 PM
cwyates4's Avatar
cwyates4
Look under the storage lid on the drivers side of the hatch, should be a list of three digit codes there...write 'em down and pm them too me and I can tell you what all your car came with stock.
If the list isn't there, try the other side, or under the center console lid.
To Gear help
