SOTP Modifications with a 700R4
Old Aug 19, 2008 | 10:27 PM
rodj's Avatar
rodj
"it wont auto shift to 2nd and I'm worried about slamming it in manually"
Put a quality shift kit in and shift it down manually; instant
Old Aug 19, 2008 | 10:32 PM
cwyates4's Avatar
cwyates4
15-20mph roll, drop to first and step on gas...OMG!
Old Aug 20, 2008 | 05:12 AM
dan_t's Avatar
dan_t
had a play with dropping it into second last night while at 60mph - its just the answer I was looking for...
felt un-natural to start with as it wouldnt have been something I would have tried with the stock L98 lol
Old Aug 20, 2008 | 01:07 PM
cwyates4's Avatar
cwyates4
whew! dropping to second at 60 mph! Musta been fun........gotta get my car back!
Old Aug 20, 2008 | 08:02 PM
hexane's Avatar
hexane
I've been down the strip hundreds of times already and so far, my stock Dana 36 refuses to go. I've been cutting quite a few 60' times lower than 1.7 seconds and DEAD hooking, but no breakage yet. I'm still driving this car on the street on weekends with the big 4000 stall.
Old Aug 20, 2008 | 08:04 PM
cwyates4's Avatar
cwyates4
You are lucky than Hoobly. Looks like the rear going in mine also caused some transmission damage...
Old Aug 22, 2008 | 08:24 AM
dan_t's Avatar
dan_t
I keep hearing of Dana36's that seem to take the abuse of the drag strip - Was there any different models? Some stronger than another?
It would be nice to know! Maybe we should have a Poll?
Old Aug 22, 2008 | 10:15 AM
Calderone's Avatar
Calderone
Dana44 is the answer
Old Aug 22, 2008 | 10:29 AM
383vett's Avatar
383vett
12 bolt works better!
Old Aug 22, 2008 | 11:04 AM
dan_t's Avatar
dan_t
I dont think either answers the question at all... lol
Old Aug 22, 2008 | 11:23 PM
rodj's Avatar
rodj
There are no variations within each type;
as in no heavy duty D36.
Only two stock choices.
D36 from a auto and D44 from a manual.
Old Aug 22, 2008 | 11:28 PM
Calderone's Avatar
Calderone
is it true the D44 can take much more abuse than the D36 ?
Old Aug 23, 2008 | 04:49 AM
  #33
dan_t's Avatar
dan_t
obviously... but how much torque can a dana36 take? 350ftlb? 370ftlb? wouldn't it be nice to know?
Old Aug 23, 2008 | 10:29 AM
  #34
bobmic93's Avatar
bobmic93
Originally Posted by Fastmax32168
I am going to go say you will see a big smile on your face with sticky tires. With my street tires 1st gear (the hardest accellerating one) is almost useless, as at anything under about 30 MPH, if I punch it the tires go up in smoke, and the car goes nowhere. With my drag radials punching it in 1st is like being launched from a cannon.
A quality higher stall converter will help that third gear condition as it will allow the motor to be in that powerband all the time. But you have to hook that power up first.
Roy
High duration cams require high stalls. (higher then 2200). If your anywhere in the 230 range for cam durations a 2800 stall minimum to take advantage of the power. Higher gears is also needed. At least 3.45s . The difference will be night and day. You will sacrafice milage though. A 3200 stall from Vigilanti felt tighter and smoother then the 2400 stall that came with my new tranny. With a Vigilanti you wont be able to tell you have a high stall till you mash the pedal.
Old Aug 23, 2008 | 10:37 AM
  #35
bobmic93's Avatar
bobmic93
Well my D36 is holding up to 350lbtq to the wheels. I have probably 20 passes down the track. I have 315 Nitto Drag radials, 3.73 and 2400stall
and Im seeing 1.7 60' times. I might be one of the lucky ones. If I had a D44 I would throw a bigger stall in there.
Old Aug 23, 2008 | 10:49 AM
  #36
cwyates4's Avatar
cwyates4
Must be! I don't have exact numbers, but I would guess I'm around 400 ftlbs to the wheels. I had 3.73s, 2800 stall, and MT et streets. Never took it to the track, never launched hard. Just a few downshifts and some WOT shifts.
Now, I have a dana 44.
Old Aug 23, 2008 | 01:04 PM
  #37
Hotred94's Avatar
Hotred94
Over the years I've learned that the flat torque curve of the LT engine makes it hard to feel and appreciate any power increases. An automatic makes it even harder. I kept modding and thinking, humm, didn't seem to do much, but the whole powerband keeps moving up, not just the peak. On a peaky engine its easy to feel how each mod affects the powerband. A good 9 inch TC will help.
