C4 Trans (auto) problem
Old Jan 2, 2002 | 01:48 PM
Plasticman's Avatar
Plasticman
Default C4 Trans (auto) problem
A buddy of mine has a 93 with the 700R4 trans. It has an odd problem of reving higher in 1st gear before it shifts into 2nd, and when it does shift, it is prolonged and soft / slipping (not hard, like an improperly adjusted TV cable would do). All the other gear shifts are at the correct RPM and firmness (depending upon throttle position).
We tried adjusting the TV cable in and out, and the correct adjustment is where it was originally (loosen the cable, mash the throttle to set the adjustment).
We changed the filter / fluid, and re-torqued the valve body bolts with no change. The fluid was clean (no sign at all of burning). Did find a couple of chunks of old pan gasket in the pan though, but the filter was not blocked (someone did a very sloppy job on a fluid change previously). Pan residue was normal clutch material and very light (last changed 50K ago). Very light amount of metal on the magnet.
This sounds like an accumalator / seal or perhaps a band? Any suggestions?
Thanks,
Old Jan 2, 2002 | 04:14 PM
OuTLaW's Avatar
OuTLaW
Default Re: C4 Trans (auto) problem (Plasticman)
Ouch on the gasket chunks. This could very well be the problem if a chunk got past the filter which is possible. From here next thing i'd do is open it back up, drop the valve body, clean everything in the valve body and be very careful to note exactly where everything goes and don't lose anything. Most tranny shops will rebuild the body if this is beyond your scope of knowledge. It sounds like a check ball is stuck or broke a spring. You'd be able to tell if you remove the body.
Good Luck!
Old Jan 2, 2002 | 04:48 PM
93 ragtop's Avatar
93 ragtop
Default Re: C4 Trans (OuTLaW)
The 93 TV cable does not adjust like the older ones. IE: release and then floor gas pedal. The factory manual has the details, but it involves using a inch pound torque wrench and setting it at the ASR unit. I mailed this procedure to RAYSUR since I didnt have a way to scan and send it. If you ask him he might be able to e-mail it to you.
Old Jan 2, 2002 | 07:19 PM
BBA's Avatar
BBA
Does it do the same 1-2 shift if the gear selector is in the "D" or "3" position as opposed to the "OD" or "4" position? This can be a critical clue.
BTW: If the band is worn down, 4th gear will be sloppy feeling also
Old Jan 2, 2002 | 09:06 PM
snaketr's Avatar
snaketr
It is possible that you have a small internal leak. Does it happen all the time or just when it is cold.
Old Jan 3, 2002 | 01:28 AM
Plasticman's Avatar
Plasticman
Default Re: C4 Trans (snaketr)
Guys,
Thanks for the help!!!
I will check to see if it happens in the other gear selector positions (good idea!).
It happens all the time (cold or hot).
3rd to 4th shift feels good all the time (so I have to assume the band is good).
Red86 4+3: Thanks for the brain update. I can get the info on how to set it.
I have dropped a few valve bodies in the past, so I guess this one is next.
Thanks again, and if you have any other suggestions, please advise.
Old Jan 4, 2002 | 01:58 AM
Plasticman's Avatar
Plasticman
Default Re: C4 Trans (Plasticman)
Confirmed that it happens in any gear shift position.
To C4 Trans (auto) problem
