Alternators choices best price??
Not good seeing I discovered this in Boston! :eek:
Needless to say I drove back during the day! :rolleyes:
Anyways, what brands do you like?
and where do I get one for the best price?
BTW, the higher amp options this guy offers will not last longer, IMO. Not a good idea in a CS-130 case.
Only second alternative I would do is take the alternator to a local rebuild shop and let them do it. I fould a guy less then 5 miles from my house that has been in business for something like 40 years, recommended by my local marina. He did a great job, and that is what is in the car right now. Rebuild took two business days only because I got it to him late in the day and he had a emergency.
Brand New or Local rebuild (small shop - one two guys tops) is my recommendation.
Good Luck,
Pete
I plan on running both in the pits.
So it sounds like I should get the high amp output.
The "iceberg" unit sounds interesting.
I have heard that the altnerators on our cars fail quickly - don't know why.
Jeff
You need lots of reserve battery power, higher amphour. If you plan on running the fan and pump w/o the engine running (that's the idea) for a long time then aux battery or charger is a good idea. In either case, larger capacity alternator is not help. If you do need higher capacity alternator then make sure it's in a much better package then the CS-130 case - the heat will kill it even faster.
Pete
Jeff
Another thought, when let the battery get too low this puts a strain on the alternator (and causes heat). So lots of cycles of low battery charging by the alternator will reduce the life of the unit. That's why it's a good idea to bring a back-up fully charged battery and let it do the cool down work. Or if you can throw a charger on it in the pits, this would be great.
Pete
Pete
I think this is what you need:
http://www.alternatorparts.com/CS-144_Special_offer.htm
[Modified by AquaMetallic94LT1, 6:45 PM 1/2/2002]
Subj:iceberg alternators
Date:1/3/2002 1:09:34 PM Eastern Standard Time
To:nqs12@aol.com
Sent from the Internet
I have a 95 Chevy LT1 Corvette that is in need of an
alternator.
Which alternator do you recommend?
It sees a lot of track/autocross/drag usage
It is also my daily driver.
Would you recommend your iceberg alternator?
I interested in both fully rebuilt units, as well as
the kits.
thanks.
----------- Brian Thomas Cunningham -------------------
e-mail brian.cunningham@eds.com
Brian:
My application guide says that your Corvette came standard with the CS-144 alternator. Our CS-144 alternators are brand new not rebuilt. They are built using all new OEM Delphi Automotive Systems internal components. They come directly from Delphi which is GM's original equipment supplier.
Thank you,
Randy
alternatorparts.com
Before that, I had a Pep-Boys with the 'you will spend your lifetime replacing this POS' warrenty. Went through one about every 2 months.
http://www.powermastermotorsports.com/
You will not regret using them! :cheers:
I'm sure they "can" be rebuilt. He probably has the kits, but CS-144 may need some "special tools" to get it apart. I have a similar unit on my Suburban, I think a 144D?
Give him a call, he's a good guy. Could probably send you in the right direction. Pretty sure I caught him on a friday night around 6:00 and he spent a bunch of time on the phone with me, very helpful.
Good Luck,
Pete
Just make sure you keep the reciept in a safe place, you'll need it.
Vic
The cheaper alternators seem to be rebuilt with diodes that were not produced in a "clean room." This results in diode degradation over time -- so your alternator fails after about a year.
The last time I needed a "good" alternator, I called the Ford dealership (for my Ranger, not my Vette) and tried to get a factory rebuilt alternator. They said they would have to order it. I told them I needed it immediately and I didn't want any "junk lifetime warranty cheap stuff that fails in a year." He told me he knew about the problem and told me to go to a NAPA dealer and ask for a good alternator and specifically tell them that I didn't want their cheap alternator that they sell to compete with Pep-boys, Autozone, etc.
After many replacement "lifetime warranty" alternator failures, I now use the good "one year warranty" alternators that don't fail but cost more -- never had a problem since.
In another life, I worked for a company that produced silicon diodes. We produced them in a clean environment (with people in "operating room" attire) -- this is absolutely essential to prevent contamination of the silicon, but it is also expensive to maintain the environment. Companies that produce them cheaper don't use a clean environment and these diodes end up in the cheaper alternators. This results in an alternator with a time-bomb ticking.
Tom Piper
