1990,fuel return line, square block with Disc
Old Aug 19, 2008 | 06:55 PM
Midday's Avatar
Midday
Default 1990,fuel return line, square block with Disc
What is this?Its the inline block with disc on it, on the return line right before the line threads into the fuel rail return line. Could not find in FSM.
Old Aug 19, 2008 | 07:44 PM
rodj's Avatar
rodj
Pulsator to dampen vibrations in return line
Old Aug 19, 2008 | 10:05 PM
Midday's Avatar
Midday
Default Pulsator
Thanks rodj, so I take it there are two pulsators? The pulsator I found in the FSM is in the fuel tank, installed between the fuel pump and the fuel level meter fuel feed tube.
Old Aug 20, 2008 | 04:59 PM
Midday's Avatar
Midday
Default ?
Also I wanted to make sure that this piece is indeed on the return line and not the feed line.
Old Aug 20, 2008 | 11:13 PM
Mo_Bandy's Avatar
Mo_Bandy
In any case you are correct it is the return line, it could also be the fuel regulator. If there is a vacuum line connected to it.
MO
To 1990,fuel return line, square block with Disc
