Has anyone experienced waterpump drive bearing failure? If so , what did it sound like? Has anyone experienced waterpump gear noise, what does it sound like. Thanks
For clarification, I'm referring to the waterpump drive gear/bearing that is mounted to the block and is driven by the cam gear behind the timing cover.
On what year and why do you ask.Of course bearings fail and coolant leaks out of them on a LT1.Various sounds occur from a gravely sound to squeaking it would be easier if you describe what you have?
My LT1 engine is emitting a whining/whistling sound that goes up & down with rpm. I have removed the belt and the sound is still present. I have checked for air leaks and others, none found. I know that gears can make a whining sound as in a timing gear drive set so the only gears in the engine are driving the waterpump, therefore my question. The waterpump drive also has a bearing, they to can whine. So can anyone verify this to be a real problem? Thanks (1996)
Take a look at the WP bearings in the below thread. The bearing seal had deteriorated, and bearings exposed. Scary thing is, there was no audible grinding or scratching when car was running. The WP began to leak onto my Opti, causing intermittent idle surge when the engine was hot.
It appeared that none of the bearings actually fell out, so that is probably why I didn't hear any grinding or squeeling from the WP.
Thanks Mike, but you guys are not reading my post, I'm not talking about the waterpump bearings but the driveshaft bearing that is behind the front cover and connects to pump shaft via a splined coupler. http://www.9c1.com/technical/LT1_rebuild/ar99928.htm
Check this site and about mid way down the page you should see the pump with it's gear drive attached. right above it is the gear and shaft alone.
I have never read of that being an issue I suppose anything is possible but I highly doubt that is your issue. I would suggest using a mechanics stehoscope to ID the location a little more.Listen to and check the WP and vacuum lines.
