Fuel Lines, Which is feed, Which is return
Old Aug 20, 2008 | 09:38 PM
Midday's Avatar
Midday
Default Fuel Lines, Which is feed, Which is return
Couldnt get an answer earlier. Trying to ease my mind. Installed miniram want to make sure I connected feed and return correctly. One line from tank has that block with disc thing on it and the other doesnt. Which line is the feed and which one is the return.
Old Aug 20, 2008 | 09:44 PM
cwyates4's Avatar
cwyates4
I don't think they are interchangeable. The feed should be larger than the return, at least, thats how my '85 is.
Old Aug 20, 2008 | 11:09 PM
rodj's Avatar
rodj
Line with pulsator on it is return line
FYI ;
the early models had different sizes 16mm supply , 14mm return;
on the later models both are 16mm
Old Aug 20, 2008 | 11:10 PM
Mo_Bandy's Avatar
Mo_Bandy
The line connnected to the fuel pressure regulator ( disk thingy) is the return line.
Best regards,
MO
Old Aug 21, 2008 | 05:51 AM
Midday's Avatar
Midday
Thanks for the help guys. I do have them installed right then. The guy tuning my car questioned this.
To Fuel Lines, Which is feed, Which is return
