A/C vacuum hose routing?
Old Aug 21, 2008 | 09:15 PM
hz900's Avatar
hz900
Default A/C vacuum hose routing?
'90 model
I know where the controller is under the driver's side, and I can see the vacuum hoses hooked up properly, but where does the vacuum hose pass through the firewall. I read it was on the passenger side, but I can't find it (I don't have it hooked up currently in the engine compartment so I can't follow the existing hose). Also can I see it on the inside where it passes through and what does it hook to?
Old Aug 22, 2008 | 03:33 AM
pablocruise's Avatar
pablocruise
There is supposed to be a 3 way check valve on the end of the line there. I forgot to put it on when I took the pic. No I am not an albino.
It draws vacuum from the intake plenum.
Old Aug 22, 2008 | 06:17 PM
hz900's Avatar
hz900
Thank you so much. I didn't know the elec. a/c was still used vacuum for the doors so when I put my car back together I didn't even look for a vacuum hose to the inside........ and I would have never found that. BTW do you know if it will cause any harm if the check valve is bypassed?
Old Aug 22, 2008 | 06:51 PM
MK 82's Avatar
MK 82
If you bypass the check valve the vacuum reservoir will not hold vacuum.
To A/C vacuum hose routing?
