Engine dipstick removal
Old Aug 23, 2008 | 09:44 PM
M. Schumacher's Avatar
M. Schumacher
Default Engine dipstick removal
1996 LT1
Other than the bracket at the exhaust manifold, is there anything holding the dipstick tube in? I have the bracket nut off however the tube still seems to be firmly in place.
Old Aug 23, 2008 | 09:55 PM
MK 82's Avatar
MK 82
It's a press/interference fit.
Old Aug 23, 2008 | 10:23 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Just give it a good pull and twist at the same time. It can take some time put it will come out.
Old Aug 23, 2008 | 11:46 PM
JackDidley's Avatar
JackDidley
I had to drop the oil pan and drive it up from the bottom. Not as bad as it sounds. About 45 minutes total on my 87.
Old Aug 23, 2008 | 11:58 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Mine tapped out with a small hammer after removing it from the stud and tapping the bracket on top of the tube upwards away from the motor.
Some twisting helped too.If it wont budge,it may be seized and other methods like dropping the pan may be required to push it out from down below.
Mine was super easy though.No pan dropping required.
Old Aug 23, 2008 | 11:59 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Vader86 describes a procedure on his website where you attach a cable/slidehammer to the tube and back it out that way.
I haven't read it recently, but it in with his description of installing headers. Sounds easier than pulling a oilpan -- unless it needs a gasket anyway.
To Engine dipstick removal
