My first Vette
Now I ask what am i getting myself into here? am I going to be pulling this motor out soon and puting a new short block in? My local bumper to bumper clames they can order the short block all together for $995 i Dought it but maybe.
And last question for now has anyone seen this color combo before?
I'd keep the Deere to sell because you can buy a nice street bike for $5500.
You should expect to do a lot of regular maintenance and repairs. New hoses, new belt, new plug wires, new plugs, new pads, rotors, replace all fluids, pull the radiator to clean imbedded garbage in fins, etc. Torn seat, bad rugs, sounds pricey for the condition and the mileage. See what other 92 or later vette's with 100K are out there in your area and compare but I wouldn't be at all surprised if you could do better. Unless you're into doing your own restoration work, BUY THE BEST USED VETTE YOU CAN AFFORD. There are a lot of vette owners who strive to keep their vettes in as mint condition as possible, even with 178K miles.
One more point. It's a vette. If it doesn't run strong, run, don't walk, away from it.
Welcome, where do you live?
It being a 92 is good, seat covers are @$200 at Iggee and carpet is @ the same.
Just check it out to see if he maintained it well or took shortcuts.
I'd keep the Deere to sell because you can buy nice street bike for $5500.
that is a boat load of miles. You should ask him if he has documentation of work that has been done on the car. Personallly, I would not buy any car, any make with that high of mileage....just to much work and too much worry.....rings, valves, rockers, pully bearings(PS, Idler, AC compressor, ALT), Opti, WP, bushings, wheel bearings, U-joints, tranny...... ad infinitumjust be smart if you go through with this deal......Good luck
Simple like that.
A SBC well maintained could run for another 100k so if it keeps running than you are way ahead
btw i live in southwest Missouri
Lots of people that have dreamed of getting a Vette see the pricing drop and want to jump on it without knowing what they are in for...Most end up hating Vettes..hence the famous quote..."I had a Vette once, years ago and it was the biggest POS I ever owned"
The C4 Vette is getting to the point where the cheap ones are going to require owners that want a project car/hobby, do the work themselves, have the funds, albeit little by little, have time and don't care that they are spending more than they will ever get back but get a ton of satifaction after getting it the way they want.
The other folks in the C4 market are the people that take alot of time finding a really well kept C4 and can afford the higher end of the pricing as in maybe over $10K and even up to and over $15K depending on the models. These cars, even with higher milage, will have all the maintenace done and/or documentation and it will show upon close inspection of the car. These owners will have the least headaches but spent more cash...
If the Vette you where considering was in great condition..even with 172,000 miles...If you get it cheap enough there are always options for a motor, such as Golen engines..you would still end up spending over $12k total (car included) but have a fresh zero mile motor...
Good luck.
