My 94 LT1 won't start
Old Aug 27, 2008 | 02:42 AM
RedHot94's Avatar
RedHot94
Default My 94 LT1 won't start
I last drove my 94 LT1 2 days ago and everything was fine. I tried to start it this morning and it won't start at all. There's plenty of power in the battery to turn over the starter. Gas is fresh from last weekend.
It's acting like it isn't getting any gas. I wondering if it might be the fuel pump but just guessing at this point.
Any suggestions would be most appreciated.
Thanks!
Old Aug 27, 2008 | 04:47 AM
vette079's Avatar
vette079
Any fault codes?
Old Aug 27, 2008 | 08:17 AM
JimiHendrix's Avatar
JimiHendrix
When you turn the key to the on position. . . without cranking, do you hear the short fuel pump whine?
If you do, I would suspect ignition or alarm system malfunction.
Pull one of the spark plug wires. Leave the spark pllug in. Make certain that you have not spilled any fuel in the engine compartment. Get an old spark plug and attach it so that you could see it from the driver's seat. Crank the engine over to see if you can detect sparking..... If it isn't, at least you are started down the right troubleshooting trail.
Good luck.
Old Aug 27, 2008 | 10:13 AM
NEVRL8T's Avatar
NEVRL8T
Good luck.
Its not VATS. VATS would keep the car from turning over if it was active.
Old Aug 27, 2008 | 10:36 AM
JimiHendrix
Depends on whether alarm is stock or not.
My car has a cobra alarm system. When armed, it will crank, but won't start. . . . giving me enough time to load the double pumper........
Old Aug 27, 2008 | 11:33 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Is it a crank, no-start condition?
If so, check your coil and ignition control module (ICM). My coil died suddenly and took my ICM out with it, resulting in the same symptoms you're describing.
Old Sep 2, 2008 | 03:39 PM
RedHot94's Avatar
RedHot94
Turned out the fuel pump was fried. A power surge melted the connector to the pump and ruined it.
Thanks for the suggestions!
To My 94 LT1 won't start
