Newbie here. Some help please....
Old Aug 28, 2008 | 01:20 AM
gsgrisso's Avatar
gsgrisso
Default Newbie here. Some help please....
First want to say, hell of a nice forum, lots of info here.
I just recently took a 85(C4 right) in on trade, don't know a hole lot about the car or all the LT1 stuff yet, but learning.
It supposedly has a 383 in it, without tearing it apart, is there anything speacial I can look for to verify? I know its a long shot, but maybe are the heads different or anything? I know on older motors it is basically internal,, cranks, rods, machine work, correct?
I have already went through a lot of older posts, it seems to lack on power under accleration, and mabye a little hesitation when you mash in to it. My questions is, if it is indeed a 383 what or approximately should be my timing and do i check at WOT or idle?
Any help here for a newbie would be great.......
Old Aug 28, 2008 | 02:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Welcome to the Forum and congrats on your new '85 Vette...
Yes it's a C4 but not a LT1 (unless a LT1 was swapped in); it's L98 powered.
Indeed a 383 consists primarily of internals changes but usually comes with intake, exhaust, cam, heads changes for optimum effect and power. If it's a 383 it should fry the tires on launch.
Stock timing is 6deg BTDC, measured at idle after opening the connector in the Tan/Blk wire that comes out of the large bundle in front of the brake booster.
BTW, if you turn wrenches, the best "tool" you can have for your Vette is a copy of the FSM from HELM. This is a rather thick red bound single volume for your year that contains very useful mechanical, electrical and trouble shooting info.
Old Aug 28, 2008 | 02:58 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default welcome
Welcome to the forum. You have picked the right place. Lots of knowlageable people willing to help.
Old Aug 28, 2008 | 06:42 AM
gsgrisso's Avatar
gsgrisso
Sorry didn't get back to ya guys any sooner, server wouldn't let me log back in.
Thanks for replies, it has intake runners like my 96 Trans Am had, I assume it is a LT1 and he told me it was. What is the differece between the L98 and LT1?
To answer the question about frying the tires, it does but not like it should, if doesn't burn em off for more than about foot, seem right? Seems to me like it should be way better.
And where can I get that book?
Also, and not to sound dumb here but isn't the distruibuter cap behind the water pump? If so how do you adjust the timming?
Sorry I know I'm a dumb a**.....But really appreciate the help...
Old Aug 28, 2008 | 07:35 AM
Iroc57's Avatar
Iroc57
Don't apologize...It sounds like your car has had some work done to it so you have no idea what motor it has. Get the FSM (factory service manual) off ebay or somewhere similar. It will run you about $100 but is well worth it. If you do not have a distributor at the firewall than there was an LT1 swapped in. The L98 is more like the old school SBC. As far as power goes you have to start from scratch because you don't know if the previous owner did it right.
Good luck and welcome
Old Aug 28, 2008 | 09:22 AM
MK 82's Avatar
MK 82
Can you post a pic of the engine?
Old Aug 28, 2008 | 09:33 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
If the car has had an LT-1 installed in place of the L-98 the FSM will be almost worthless.
Old Aug 28, 2008 | 11:11 AM
65Z01's Avatar
65Z01
On the other hand he would need two FSMs, one for the '85 for most R&R and one for whatever year LT1 (OBD1 or OBD2??) to cover the engine & ECM.
Maybe the seller can give some additional info on what was done with the engine.
Old Sep 1, 2008 | 11:03 PM
gsgrisso's Avatar
gsgrisso
OK sorry it took so l;ong for me to get back to you guys, been working like dog.
OK got some pics for ya, did some playing around this weekend, it does have a distributer but has the intake that looks like a LT1? Just for fun bumped the timing just a nudge to see if it got any better, it did starts a little better and seems to run a little better, but not were it should be.
Thats a different problem, have a new one now, as you can see in the pics i have been sanding on this thing for a couple days now, the clear coat was coming off bad and the paint was crap. Somebody had painted it before but didn't strip it down before they painted it, they just kinda roughed it up a little and sprayed it. So soon as I get it painted will be hard core on getting it running right.....
Here is some pics for ya, any ideas on the motor????
How come can't post any pics???????
Old Sep 1, 2008 | 11:10 PM
BlackHarleyMan's Avatar
BlackHarleyMan
Sounds like you might have yourself a L-98 with a MiniRam, or modded LT1 intake installed. If that's the case, then I would wonder what other mods have been done to the motor, and thats where this could get VERY interesting!
As far as posting pics go, the easiest way that I've found to do this is via this method here:
http://forums.corvetteforum.com/show....php?t=1336867
Goodluck and welcome to the CORVETTE Fourm!
R/Noland Smith, Jr.
STSC(SS) USN Ret.
Old Sep 1, 2008 | 11:29 PM
gsgrisso's Avatar
gsgrisso
Thanks for the heads up on pics..........
http://s527.photobucket.com/albums/cc358/gsgrisso/
Here see if this works..
Old Sep 2, 2008 | 03:14 AM
Master__Shake_'s Avatar
Master__Shake_
Looks like my old motor. I miss that thing..
But 65Z01 is right, that is definitely an L98. Looks stock to me, actually. If that's the case then I highly doubt someone would stroke it to a 383 without changing major components. You may have dealt with a very good con artist, my friend.
Old Sep 2, 2008 | 03:21 AM
Mekanic's Avatar
Mekanic
Thats a bone stock L98 my friend.
Heres a pic of my LT4, LT1 looks the same minus the red intake and lettering.
Old Sep 2, 2008 | 03:27 AM
gsgrisso's Avatar
gsgrisso
Yes it might have been a long line of BS, but in all reality I only have about 1200 hundred bucks in the car, so if it is not the 383, thats OK to, just something else I can do later and know for sure exactly what I got....
Old Sep 2, 2008 | 06:25 AM
rons85's Avatar
rons85
Bone stock (and probably tired) L-98. Still has all of the AIR stuff on it, along with some shade-tree additional wiring for Something (Fan, perhaps). Good luck with it - and hope that the PO wasn't full of you-know-what about the Rest of the car..
LTI - Sheez...
Old Sep 2, 2008 | 08:19 AM
Iroc57's Avatar
Iroc57
I gotta say that after seeing that pic you should STOP right now!!
Get the FSM and read it for each project BEFORE you dig in. Ask questions here first if there is something that you don't understand. There are lots of " I can't figure out what I did" posts here that could've been avoided by doing this.
Old Sep 2, 2008 | 02:03 PM
BlackHarleyMan
LTI - Sheez...
To Newbie here. Some help please....
