speed density?
Old Jan 4, 2002 | 01:31 AM
BowTieBlood's Avatar
BowTieBlood
Default speed density?
OK, what is the difference if any performance wise of this and a MAF? And besides performance, how does it affect the car differently?
And what years had the system? :confused:
Did any of the LT1s have this? If so, is there anything you should do to improve the performance of it, or is it OK like it is?
Old Jan 4, 2002 | 01:46 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: speed density? (BowTieBlood)
Well I know the 92-93 LT1 have it, but I have no idea what the hell it is.
Old Jan 4, 2002 | 01:53 AM
BowTieBlood
Default Re: speed density? (Mr Mojo)
Welcome to the club :lol:
Old Jan 4, 2002 | 01:54 AM
jfb's Avatar
jfb
I don't know which year switched from MAF to speed density, but they both do the same thing, and that is provide the ECM what mass of air is entering the intake so it can decide what pulse length the fuel injectors must have in order to maintain the proper air to fuel ratio for the throttle setting and engine load.
Old Jan 4, 2002 | 02:11 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
In the early L98s ('95-89) air flow into the engine is measured directly by the MAF; in the '90 & 91 L98s it is computed from MAP sensor and other sensor values. The later LT1s used a different MAF, but not sure if the early LT1s used MAF or SD.
The MAF based L98 is easier to modify as it doesn't require an EPROM change till more extensive mods have been done, if at all; whereas a SD based L98 usually requires EPROM changes to match fuel properly to computed air flow. Also it is much more difficult to get the EPROM mapping correct with a SD system.
The SD system is sensitive to mods that change manifold pressure (like cam change) while the MAF is not.
Old Jan 4, 2002 | 02:15 AM
AS84's Avatar
AS84
Default Re: speed density? (65Z01)
90-91 L98 SD cars hate changes. My car ran like dog doo before I had a chip programed!
Old Jan 4, 2002 | 12:05 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: speed density? (AS84)
My gal is a dog right now, gotta burn a chip soon :crazy:
Old Jan 4, 2002 | 02:07 PM
Mojo's Avatar
Mojo
This is simply not true. It's very easy to set up the VE tables in a SD system, and it's much more accurate than the early MAF systems because there's no scaling involved. There's also no 255g/sec limitation on airflow like the early MAF systems...
TNT-
How's the Haltec? How much was it and what did it come with??
[Modified by Mojo, 1:13 PM 1/4/2002]
Old Jan 4, 2002 | 02:32 PM
Raysur's Avatar
Raysur
Default Re: speed density? (Mojo)
I know that my friend with a '94 is jealous as hell that my intake is less restrictive than his. If he says something about my car I just say "according hose" and he shuts up:lol:. Then I rub it in that my car is more free flow than his.
I did a post way back on this. Somebody gave some real detailed information on the differences. I'll try to fnd it for you.
Old Jan 4, 2002 | 02:35 PM
Raysur's Avatar
Raysur
Here it is:
http://forums.corvetteforum.com/zerothread?id=154908
Old Jan 4, 2002 | 03:28 PM
BowTieBlood
Default Re: speed density? (Raysur)
Thanks that was very imformative :cheers:
Also, do you know which years had what? Is it '92-'93 of the LT1s that had the speed density? And then '94 up they switched back to MAF?
Old Jan 4, 2002 | 04:39 PM
Mojo's Avatar
Mojo
Default Re: speed density? (tntcorvette)
Matt???
Sorry, had you confused with HighHopes for a bit there... :D
Old Jan 4, 2002 | 09:59 PM
Raysur's Avatar
Raysur
Yes. For the L98 I think it was 90-91 that had Speed density units.
To speed density?
