Instillation and Parts Pricing
http://usengine.us/
Block Work - ~ $600
Rotating Assy Balance - $ ~$300
King Pro Rod Rod Bearings - $39.99
King Pro Main Bearings - $42.99
Dura-Bond Cam Bearings - $22.99
Scat Q-Lite 6" rods - $398.70
Manley Pistons 4.030" - $429.95
4.035 File Fit Hastings Powerflex Rings - $ $87.95
Eagle 4340 Lightweight Crank - $609.00
Victor Reinz Head Gasket - $15.95
ARP Oil Pump Stud - $4.31
ARP Oil Pump Shaft - $16.95
ARP Main Bolts - $31.95
ARP Head Bolts - $67.95
ARP Header Bolts - $36.39
ARP Blancer Bolt - $22.88
Professional Products 59mm TB (Polished)- $179.95
Cadillac Racing Lifters - $274.82
ATI Super Damper - $445.00
Reeds Custom Cam - $300.00
Champ Pans Custom CP100LTRB-RR - $258.00
Champ Pans HV Oil Pickup - $28.46
Ford "Jolly Green Giant" 42lb injectors - $320.00
AFR 195 Comp Ported Eliminators - $2600.00
Crane Gold 1.6 7/16th Non-SA - ~$200
Chromemoly Pushrods - $86.95
Mildon HD Oil Pump - $39.95
FelPro Master Gasket Set - 145.95
Spec Stage 2+ Clutch - $531.90
Spec Single Mass Steel Flywheel - $269.10
Cloyes Double Roller timing chain - $83.95
Misc bolts, plugs, NPT fittings - $ 30.00
Various Sensors (Knock, Cyl, Water, Oil Temp/Level) - $200.00
NGK TR-55 - $20.00
MSD Wires - $90.00
Percy's Dead Soft Alum Header Gasket - $28.99
68" Accesory Belt - $30.00
Valve Cover Gaskets - $20.00
2 Gallons of Rotella-T - ~$40.00
AC Delco Oil Filter - ~$5.00
I'm too tired to add the total on this up, but this doesn't include the long tube Exotic Muscle headers and high flow extension with cats that I had made for this build. Nor does it include any of the block clearing/prep work, intake gasket matching, and intake plenum work that was done by Will at no charge. Goodluck and keep us posted however you go!
One think I need to let you know............The motor as it sits, is normally just one piece of the entire picture. It's all the little bits and pieces that are going to kill you during the install that most people don't account for and make a Gazillion runs back and forth to the parts store or Summit/Jegs to get. Either way, expect the unexpected and make sure you do all the research and question asking that you can to get the best price and save as much unnecessary or wasteful spending as possible.
R/Noland
On 383's have your block sonic tested before any work is done to make sure you have a good foundation.
We try use quality parts like the Callies Compstar cranks and for 595.00 there a good deal, Ya we can buy 4340 cranks for 375 dollars but the sizing and straightness and roundness of the journal don't compre to a Callies crank.
The same with rods, pistons, rings ETC.
So far we have not really done and budget builds using cheap parts and we like to dyno the engines before they go in to make sure there are no problems and do a timing sweep ETC.
Here are some links to look over.
http://www.chevelles.com/forums/showthread.php?t=106715
http://www.chevelles.com/forums/showthread.php?t=236517
Xcel is our friend...
$600
$300
$39.99
$42.99
$22.99
$398.70
$429.95
$87.95
$609.00
$15.95
$4.31
$16.95
$31.95
$67.95
$36.39
$22.88
$179.95
$274.82
$445.00
$300.00
$258.00
$28.46
$320.00
$2,600.00
$200
$86.95
$39.95
145.95
$531.90
$269.10
$83.95
$30.00
$200.00
$20.00
$90.00
$28.99
$30.00
$20.00
$40.00
$5.00
Total $8,956
$600
$300
$39.99
$42.99
$22.99
$398.70
$429.95
$87.95
$609.00
$15.95
$4.31
$16.95
$31.95
$67.95
$36.39
$22.88
$179.95
$274.82
$445.00
$300.00
$258.00
$28.46
$320.00
$2,600.00
$200
$86.95
$39.95
145.95
$531.90
$269.10
$83.95
$30.00
$200.00
$20.00
$90.00
$28.99
$30.00
$20.00
$40.00
$5.00
Total $8,956
R/Noland
P.S. I'll keep my other thougths to myself right now, BUT as a word of warning, ask ALOT of questions and please be careful. Following a Piper in Shiny clothes might put you in ALOT deeper than YOU need, and no better quality than anyone else on here that's PROVEN themselves!
AND Typically OWN and Work with VETTES!
R/Noland
You should be dealing with someone that does all the work in house and has a good reputation out there doing performance work.
Just be aware of want to bees!!!
is there a reason you want to keep your block?
