Need help with a couple AutoXray scans
Old Sep 3, 2008 | 11:12 PM
MK 82's Avatar
MK 82
Originally Posted by 65Z01
Re '88 Vette FSM, pp 6E3-A-52 ECS Circuit "Circuit Description":
Thanks. I learned something today.
Old Sep 4, 2008 | 02:03 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The FSM is indeed a great "tool" and you're quite welcome...
Old Sep 4, 2008 | 09:08 AM
UNCLEBILL's Avatar
UNCLEBILL
UPDATE!!!!!!
Did the following checks last nite:
-pressure at fuel rail with ignition key only on....40#
-took 4 hours to bleed pressure down to 10#
-injectors--cold= 14.9 to 15 ohms
--hot = 15.4 to 15.7 ohms
I put the injectors in last year just after I got the Vette (see my earlier posting for reason) and all worked well for 2500 miles until a week ago. At cold my power taking off wasnt there and the tranny was searching for a gear. Until the engine warmed up and the TC was locked; then it would perform properly.
All the avenues seems to be covered with your help. WELL; sat down last nite and started to read the tranny section in my FSM..got to the TV cable adjustment. I pushed the button in ..let go and moved the throttle lever and it ratchedup. I then redid it properly per FSM.
Took the Vette out this morning...cold start..no TC lock up and it ran FINE!!!!
IT WAS THE TV CABLE NEEDING ADJUSTMENT!!!!!!!!!!!
I would like to thank all the above people who took the time to help and walk me thru my problem. I learned a great deal from you guys!!!
Thanks for all your help and Patience!!!!
Bill
