cams
Old Sep 1, 2008 | 11:51 PM
vettlag's Avatar
vettlag
Default cams
compcam which one should i get 5.7 tpi biggest and best sounding.
Old Sep 1, 2008 | 11:58 PM
neat's Avatar
neat
That's a super broad question, too broad to really answer. You might as well have asked, "I'm going to Europe, know any good places to eat?" We don't know what kind of food you like, where you are going in Europe, what your budget is, etc...
With your car we don't know your goals, tuning ability, how you plan to tune the car, etc...
If you are looking for more power than stock, but decent drive ability the CC305 is tough to beat. It's almost identical to the GM LT4 hotcam, just a shade bigger.
I don't really like the CC306, but you can't argue with the results some have put up with it. It also sounds pretty tough at idle.
Lots of the relatively new XFI grinds are good, I put the 280 in my car. My car is still torn apart so I don't have any first hand experience with it, but I think it should work pretty well.
You won't see much of a gain without doing away with the TPI intake system. Any cam with some meat on it is going to want to rev past 5000, and anything resembling the stock TPI just won't support something like that.
Good luck, let us know what you decide to do.
Old Sep 2, 2008 | 12:45 AM
vettlag's Avatar
vettlag
decent driveability the tpi will stay on. looking to freshin up it has 354 gears o-60
Old Sep 2, 2008 | 01:15 AM
vettlag's Avatar
vettlag
can i put a cc305 or 306 in a stock 5.7 tpi 85
Old Sep 2, 2008 | 01:17 AM
racebum's Avatar
racebum
short answer: no
both require more spring pressure & also greatly benefit from an increase in intake and exhaust flow.
Old Sep 2, 2008 | 01:18 AM
rodj's Avatar
rodj
Wasting your time with big cam UNLESS you do other mods to suit
Engine is complete package; just changing cam without exh / intake / head mods to suit=
Old Sep 2, 2008 | 01:35 AM
vettlag's Avatar
vettlag
its got melrose headers 3"pipes xpipe flowmasters planned on doing the heads ,springs, w 1.6 roller rockers.comps 268 was my other choice but not sure on the sound
Old Sep 2, 2008 | 02:54 AM
Master__Shake_'s Avatar
Master__Shake_
Compcams has a group of hyd. flat tappet Thumpr cams that makes a really nice lopey idle, like their roller cam sets, for the price of a normal flat kit. The number is CL12-600-4 on summit.com, and is about the biggest you want to go without doing MAJOR intake work. Porting your heads(since your profile says intake is ported) will make the best of it, along with a 2200+ stall converter. Your current gears are good for the setup.
Hope this helps.
Old Sep 2, 2008 | 07:42 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
All excellent points. and I have to ask, to remain consistent, Comp is a great company, but did you consider any other cams? Or a custom grind?
Have you considered future mods? The cam is the heart of the engine and will dictate whatever you do going forward. Intake, heads, exhaust, will all be based around this cam. I'd think a little further ahead, sacrifice a little today for what you will have tomorrow. Unless there are no future mods.
To cams
