Re: [HELP] Check Engine Light on stock 96 LT4 (kewlbrz)
Its usually emission related code like o2 sensor. I would take it to another dealer and run a code check. A code is always stored in the computer for future access by the dealer. Mine comes on then goes off every now and then.
No big deal.
I replaced my gas cap for $5 and solved my problem same symptons as your friends car. Also make sure to tighten it at least 3 clicks and push down while tightening. FrankLT4CE
