How much power can a TH700R4 Handle ?
Old Sep 3, 2008 | 06:17 PM
Calderone's Avatar
Calderone
Default How much power can a TH700R4 Handle ?
Is it really weak like i've been hearing from local folks ?
i dont think that its so weak !
Old Sep 3, 2008 | 06:20 PM
Pete K's Avatar
Pete K
How high is up?
How long is a piece of string?
I have many in cars that run as quick as 10.70 @135 mph
When done right, and the right converter is hanging on the input shaft. They live.
Old Sep 3, 2008 | 06:29 PM
Demonic85's Avatar
Demonic85
Originally Posted by Pete K
How high is up?
is that one of your built up ones or a bone stock one?
Old Sep 3, 2008 | 06:35 PM
Pete K's Avatar
Pete K
Believe it or not, my stock trans ran a 10.90 @ 130 with a 150 shot of spray. I was very lucky. Next run, my luck ran out, and I ripped the center piece out of the case.
I build them up pretty well to get them to run 10's and remain somewhat reliable.
Somewhat is the key word. I don't care who builds them, it is very hard to build them tough enough to go like the energizer bunny. At that power level, they need refreshing every so often.
Old Sep 4, 2008 | 01:31 PM
dan0617's Avatar
dan0617
My stock '89 700R4 is surviving still. I dyno'd 417 rwhp and 419 rwtq on a Land and Sea dyno on a 150 shot. I've since fixed a few issues and installed the 175 jets and it is still holding up strong. Have a B+M shift improver kit, 2800 tcs converter, and a tranny cooler. Other than that it is bone stock. Living on borrowed time, but living nonetheless.
Old Sep 4, 2008 | 01:34 PM
dan0617's Avatar
dan0617
Calderone, the newer ones are more durable, what year is yours? I'm not sure why you are asking but I wouldn't hesitate in modding the car. If you reach the majical unknown power number in which the trans comes unglued, contact PeteK. I'm sure I will be contacting him eventually!
Old Sep 8, 2008 | 02:06 PM
Calderone's Avatar
Calderone
Old Sep 8, 2008 | 02:30 PM
mseven's Avatar
mseven
and what is the right converter ?
Old Sep 8, 2008 | 05:17 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I run 9's with my 700 but it is far from stock.The stock trans made it to 10.83 at 128 mph and it was done.A 9 inch converter and manuel valve body is the only way to realy get it to live,I also have 2 trans coolers .
It realy is a 4 speed without the clutch.
If you want to race the car don't ,if you want a race car buy one .
If you have big $$$ then go ahead and set the car up to race ,I would start with rapter trans in La.6k and see skii_down for a rear at $4999.95 and you are almost their
Old Sep 8, 2008 | 06:05 PM
Orr89rocz's Avatar
Orr89rocz
yep my buddy was doing high 10's on his 700r4 then switched to a th350 i think when the 700 blew
They can hold some power. I'm beating mine up with 400whp so far and its holding. Only mid 11's but i abuse it
Old Sep 8, 2008 | 06:13 PM
Pete K's Avatar
Pete K
There are many. I happen to have a good source as well
To How much power can a TH700R4 Handle ?
