transmission lines..
Old Sep 3, 2008 | 09:09 PM
mattsoltesz's Avatar
mattsoltesz
Default transmission lines..
Ok...i figured out the leak is from the transmission lines on the passenger side of the engine compartment. I cant see the exact leak but i know its those lines....question is....how much of a task is it to change those lines? Has anyone done it???
Old Sep 3, 2008 | 09:13 PM
Pete K's Avatar
Pete K
Cut the bad section out, and install a new section of tubing with compression fittings or flared unions.
Repairing them is easy. Replacing them is a bitch.
Old Sep 3, 2008 | 09:19 PM
pablocruise's Avatar
pablocruise
Check out 86PACER's thread, exact same problem:
http://forums.corvetteforum.com/show....php?t=2030677
good pics in there.
To transmission lines..
