Must overfill transmission
Old Sep 3, 2008 | 10:41 PM
banctecbobn's Avatar
banctecbobn
Default Must overfill transmission
Why would I need to suddenly overfill my transmission to get it to work correctly?
If I overfill by a quart or so the transmission shifts and works correctly.
If I don't overfill the transmission it feels like it slips, more like the converter is slipping. It appears or feels like the transmission stays in third gear (at least I can't feel or hear it shift) and it will not shift into overdrive. No matter how far I drive or the transmission warms up it still will not work correctly. If I run the car down the road a couple miles, put it in park and shut off the car, wait a few seconds, then restart it will work perfectly from that point on till the next day. I know the oil level raises while warming up but it seems strange that I must shut off and restart to get it work.
1994 LT1 automatic and no changes were made.
Old Sep 3, 2008 | 10:52 PM
Lichen's Avatar
Lichen
You should NOT overfill it. Are you checking with the engine hot and idleing?
Old Sep 4, 2008 | 07:48 AM
banctecbobn
Yes, hot and at idle.
This is my problem, I HAVE to overfill to get it to work correctly. I've had this car for years and I know the level it has been in the past. I need to know what would be wrong/failing in the transmission that would require a higher fill level.
Old Sep 4, 2008 | 09:59 AM
Chatman's Avatar
Chatman
Could you have a clogged or damaged filter that at least partially prevents flow until you add enough that another route is possible?
You're asking for guesses, right?
Old Sep 4, 2008 | 10:48 AM
banctecbobn
NO, no guesses....I can do that all day myself. Looking for an explaination from someone who has had this problem or an experienced transmission man that know what their talking about.
You could be right about the filter.
Old Sep 4, 2008 | 11:47 AM
adi4's Avatar
adi4
Yes a clogged filter it could be, but another possibility is a hairline crack in the filter neck, I have seen this before and it will draw air rather than oil, the higher oil level might just be covering the crack.
Either way I would pull the pan and the filter and have a look, install a new filter and pan gasket
Adrian
A B M
Old Oct 27, 2008 | 07:22 PM
banctecbobn
Well, I changed the filter, seal, and fluid and I still have the same problem. Any ideas????????
Old Oct 30, 2008 | 08:07 PM
banctecbobn
Any transmission guys on this forum????????????????
Old Oct 31, 2008 | 10:20 AM
NEVRL8T's Avatar
NEVRL8T
Pete Kane
http://forums.corvetteforum.com/member.php?u=58966
Old Oct 31, 2008 | 12:17 PM
car5car's Avatar
car5car
Filter fell off.
Old Nov 9, 2008 | 10:48 PM
banctecbobn
I replaced the filter and still have the same problem. Please read all post before replying please.
To Must overfill transmission
