clutch master pushrod????
Old Sep 4, 2008 | 08:33 AM
snookman4's Avatar
snookman4
5th Gear
Default clutch master pushrod????
Help!!! my 87 coupe has a pushrod for the mastercylinder with an eggshaped (bad) washer that doesn't match up with the 87 cylinders being sold. The fix by United is use the new master with the old pushrod but it's the pushrod (specifically) the washer on the pushrod thats bad. The hole size on the new one is too small and there is also a plastic bushing in the old one ie: if you drill the new one out what do you do about the bushing to attach to the pedal mechanism? Any help appreciated, the mechanic working on it replaced clutch, slave and master only to use the old pushrod and find out that was the problem all along along with the master being bad from the pushrod.
Old Sep 4, 2008 | 10:04 PM
lltrevino's Avatar
lltrevino
my master cylinder went out 3 weeks ago. and when i pulled the master out, my was egged about 3/8". so, only way to change rod, is to disassemble master. I just did not use the plastic bushing. only way it would go on. later I imagine, it will egg again
