Injector replacement -- what else is needed/suggested?
Old Sep 5, 2008 | 12:16 AM
josephf31's Avatar
josephf31
Default Injector replacement -- what else is needed/suggested?
Getting ready to replace the injectors on my '91 L98 auto -- besides the injectors themselves, what, exactly do I a) *need* (gaskets, gasket sets, o-rings, seal, etc.)? and b) *should* check or replace while I have the top end apart (fuel pressure regulatory, any sensors, etc.
Thanks for your assistance!
Old Sep 5, 2008 | 07:43 AM
chevylu's Avatar
chevylu
Here you go:
Bob Lam’s article on injector removal
http://webpages.charter.net/buddiel/...al)%201-04.doc
Motorcraft fuel injectors
http://www.fuelinjector.citymaker.co...ge/5516057.htm
MotorCraft# Ford# Bosch# Borg Warner#
CM-4768 F4SE A1B 0280155700 57810
Injector flow data table
http://users.erols.com/srweiss/tableifc.htm
Injector flow rates
http://www.witchhunter.com/injectordata1.php4
1985-1993 Corvette, Camaro Pontiac T/A Bosch Design III upgrade Fuel Injector
http://fuelinjectorconnection.com/sh...&productId=134
Doug’s Dirty Dozen
http://www.lindertech.com/dirty_dzn.htm
TPI Injector Replacement
http://www.thirdgen.org/injectorswap
1997-2004 Fuel Injector Replacement
http://www.vetteweb.com/tech/vemp_07...ors/index.html
NOID light
http://www.drivewerks.com/catalog/Sh...AT447_pg28.htm
How to change your fuel injectors
http://www.corvettefever.com/howto/c...uel/index.html
Understanding Fuel Injector Wave Forms
http://www.automotivetestsolutions.c...rWaveforms.htm
Intake Plenum Gasket
http://www.autozone.com/R,APP1104544...ductDetail.htm
Fuel rail seal kit
http://www.autozone.com/R,APP1136249...ductDetail.htm
Valve Cover Gasket
http://www.autozone.com/R,APP673059/...ductDetail.htm
Old Sep 5, 2008 | 09:39 AM
Kool88vette's Avatar
Kool88vette
I would rebuild the fuel pressure regulator. I removed the fuel rails when I did my injectors. I polished the aluminum and replaced the gaskets and o rings on the rails.
Old Sep 5, 2008 | 01:58 PM
josephf31's Avatar
josephf31
Default Thanks
for all of the great info, I'm going to have to do some reading!
One other question, it is easier/better to replace the fuel pressure regulator with a new adjustable one? or just replace the OEM gasket etc?
Thanks again!
Joe
Old Sep 5, 2008 | 02:21 PM
GKK's Avatar
GKK
It's the same work installing a new Diaphram or an aftermarket adjustable fuel regulator.
If you buy an adjustable fuel regulator, get the Holley because it has a lower profile and a big aluminum **** which makes adjustments easy.
http://www.jegs.com/i/Holley/510/512-501/10002/-1
http://store.summitracing.com/partde...928+4294908216
Old Sep 5, 2008 | 04:52 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Are you sure these are the correct regulators for a 5.7L TPI car.
Old Sep 5, 2008 | 11:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You can get all the needed gaskets in a FelPro Top End gasket set for your Vette; Auto Zone should have them in stock.
I strongly suggest that you run the fuel level in the tank down close to empty before opening the two fuel lines in front of the intake base...
It may help on reassembly if you bag & label all the bolts as you disassemble.
Old Sep 6, 2008 | 08:14 AM
the blur's Avatar
the blur
any comments on an AFPR?
I have heard some are terrible....
Old Sep 7, 2008 | 02:24 AM
josephf31's Avatar
josephf31
Default Throttle body bypass?
What is this throttle body bypass I've read about? Is it worth it, pros/cons, and would it be any easier to so while I have it apart for the injectors or is easy enough to do by itself at a later time? Thanks!
Old Sep 7, 2008 | 06:42 AM
chevylu's Avatar
chevylu
Well worth it; now is the time to do it. I did.
If you need more info, search this forum for bypass.
Old Sep 8, 2008 | 10:49 AM
GKK's Avatar
GKK
Yes, I've used this Holley AFPR on my previous "89" L98. Fits perfectly and is very easy to adjust without any tools.
To Injector replacement -- what else is needed/suggested?
