Installing master cylinder reservoir
Old Sep 6, 2008 | 09:20 PM
ric'sblack86's Avatar
ric'sblack86
Default Installing master cylinder reservoir
HELP...is there a trick to this? The seal seems way to hugeto get the reservoir on and I have been battling it for 1 hour! Should I remove the seals from the M/C first and put them into the reservoir and then mount on the M/C? I checked and the seals are the same size as the old M/C...I am in a DUH moment! Any help appreciated!
Old Sep 6, 2008 | 09:44 PM
ric'sblack86
Opps...never mind, I got it! If you take the seals off, put them into the reservoir and then slip them on it goes easy!
