I fixed my dead drivers window by replacing the....
Sep 6, 2008 | 09:50 PM
Courtesy light bulb in the door.
Well, THAT saves me a huge headache!!
FIY.
Sep 6, 2008 | 10:17 PM
For passager window try taillight bulb replacement!
Sep 8, 2008 | 08:51 PM
I guess you're kidding about the passenger window...mine quit working last week. The courtesy light works fine...I think. I'll have to check that out.
Sep 8, 2008 | 08:56 PM
Sep 8, 2008 | 11:18 PM
Quote:
Originally Posted by
MK 82
He read it in his FSM!
Guess what? I figured this one out on my own.
Natch.
Sep 8, 2008 | 11:23 PM
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Sep 9, 2008 | 07:33 AM
formul89
FIY.
Do you have a clue how that statement sounds?
Sep 9, 2008 | 08:24 AM
MK 82
Not nearly as dumb as this one.
Give up, MK.
Sep 9, 2008 | 08:39 AM
formul89
Give up, MK.
You are right. I shouldn't pick on the challenged.
Sep 9, 2008 | 09:02 AM
MK 82
Ok, and your snarky comments add what to this forum? Other than gloating about your ability to read a service manual?
Here's a cookie for your efforts:
Sep 9, 2008 | 02:53 PM
I don't think the two circuits are related. You probably wiggled some wiring when you had the door panel off.
Sep 9, 2008 | 02:58 PM
Oh yeah, I fixed my cruise control by replacing my turn signal bulb!
Sep 9, 2008 | 03:24 PM
86PACER
That is what I was thinking, which is why I worded the thread title like that. I did not pull the door panel off, though.
The window did not work when I bought the car a couple weeks ago. Checked everything but pulling the door panel.
I took the door light lens above the handle out and found the bulb was cracked into two pieces. It looks almost like those old round glass fuses. I put the new bulb in, turned the lights on to check it, tried the window switch and the window worked.
I was surprised.
Sep 9, 2008 | 03:50 PM
And then you made a great leap of logic.
Sep 9, 2008 | 04:04 PM
MK 82
And this adds what to this thread?
Sep 9, 2008 | 04:09 PM
Likely loose contacts on the switch.
Or the connector. It's an old car and those parts get cranky.
