idle specs
Old Sep 7, 2008 | 12:37 PM
93convertible's Avatar
93convertible
Cruising
Default idle specs
Does anyone know what the correct idle speed and tps voltage should be with cam swap?
Old Sep 7, 2008 | 02:59 PM
STL94LT1's Avatar
STL94LT1
The TPS voltage will be the same as stock, and the idle rpm will depends on the camshaft.
Old Sep 7, 2008 | 03:12 PM
93convertible
Cruising
She seems to idle best around 900rpm but i'm not sure about the voltage... I've read .5 and also between .6 and .9any reccomendations?
thnx
Old Sep 8, 2008 | 08:50 AM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
.52-.56 seems to work for me.
Old Sep 8, 2008 | 12:48 PM
TPI BOY's Avatar
TPI BOY
Old Sep 10, 2008 | 11:48 PM
93convertible
Cruising
i'll try thnx
To idle specs
