How much power needed to pull in 6th?
Old Sep 8, 2008 | 10:37 AM
LT4POWR's Avatar
LT4POWR
Default How much power needed to pull in 6th?
The ZF’s 6th is 0.50, and I’ve got a 3.92 rear gear. Thanks
Old Sep 8, 2008 | 12:20 PM
vettef6's Avatar
vettef6
I have 4.10 gears and 6th is more of use to me now. I must confess I haven't driven my Vette faster than 166 mph//4400 rpm. It will run a lot faster I'm sure, but I don't really want to. Acceleration is more important to me than top speed. I think I could go 190 mph in 6th gear if I really wanted to.
Haven't been to the dyno, but I should easily have more than 500 hp.
Arnold
Old Sep 8, 2008 | 12:23 PM
Sidney004's Avatar
Sidney004
http://www.edelbrock.com/automotive_...ctor_675.shtml
Old Sep 8, 2008 | 01:42 PM
LT4POWR's Avatar
LT4POWR
Not exactly the feedback that I was hoping for. Anyway, I'd think that some of our over-analytical, theory members would have a decent guesstimate or some kinda software sim.
Old Sep 8, 2008 | 02:23 PM
LT4BUD's Avatar
LT4BUD
I don't really understand the point of your question....
In 6th gear your engine rpm is going to be quite low until you get up to a pretty high speed......look at your tach, then dyno curve and you can tell how much horsepower you have available...
Your torque mulitplication will be 0.5 times 3.92 equals 1.46...so rwtq will be 1.46 times the torque on your dyno curve...
Hope this helps, but still not sure what you are after???
Old Sep 8, 2008 | 02:38 PM
LT4POWR's Avatar
LT4POWR
I’m talking about from a top speed perspective. Sorry if that wasn’t clear. I’ve always heard that top speed is achieved in 5th due to our car’s gear ratios, hp, and aero. And that 6th gear will only bog the motor and slow it down. So, my question is…At what point do changes in horsepower and gearing make it feasible to keep accelerating after you run out of gear in 5th?
Old Sep 8, 2008 | 04:17 PM
vettef6's Avatar
vettef6
I'm with LT4BUD, don't really understand what you want and where you want to drive that fast, considering you live in the USA!!
Maybe this will help you:
With your gears you will be doing:
160 mph/4000 rpm
180 mph/4500 rpm
Now look at your dyno curve and see what you have on HP at 4000 rpm and 4500 rpm. You're no where near your max HP rpm.
At 167 mph/6600 rpm in 5th gear then shifting into 6th gear my engine still pulls hard, and could probably go 190 mph, but don't think you could with your setup. You would have to have an engine with a max HP rpm of about 5000 rpm to go 200 mph.
Old Sep 8, 2008 | 04:22 PM
LT4BUD's Avatar
LT4BUD
What happens as you increase speed the horsepower requirements start increasing very rapidly......
if you plotted horsepower required (to overcome windage, frictions, etc) vs speed and also plotted engine horsepower vs speed.....you would find that at lower speeds the motor makes more horsepower than is required to overcome windage,etc., but as speed increases the required horsepower starts increasing faster than the engine horsepower increases and finally the required horsepower is more than the motor is putting out at that speed...the curves cross and that will be the maximum speed...
problem is that in 6th gear this crossover would occur well before the engine reaches its maximum power..
do you see the picture???
Old Sep 8, 2008 | 05:19 PM
LT4POWR's Avatar
LT4POWR
I understand what you guys are staying, the question is mostly theoretical, but I figured someone around here that’s big in physics, has a computer sim, or some actually real-world feedback could chime in. I am planning on building a new motor this coming winter/spring, and plan on doing some regional mile races. Anyway, this past weekend with my current setup (obviously) I had a chance to really open it up* and it was pulling like a freight train when I got out of it at/around 6,500rpm in 5th….yes, around 169mph.
*disclaimer – private closed course, and I don’t endorse, recommend, condone excessive speed on public roads
do see the picture???
Yes, that's my point of my question....I know it's probably not an easy answer, but there's gotta be a point where power will overcome this "problem" with 6th gear.
Old Sep 8, 2008 | 05:28 PM
LT4POWR's Avatar
LT4POWR
an interesting top speed thread
http://forums.corvetteforum.com/show...ight=speed+top
Old Sep 8, 2008 | 07:27 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I'd say based on 6300 rpm would be 250 mph. Take a look at the Sledgehammer... Approaching 1000hp, and a whole lotta road and *****.
Old Sep 8, 2008 | 07:38 PM
95wht6spd's Avatar
95wht6spd
Don't know if it is true, but have read that the synchros in 6th are weak?
Old Sep 8, 2008 | 08:12 PM
cv67's Avatar
cv67
St. Jude Donor '05
A whole lot of boost. Thats an awful tal gear, withwind resistance it will take one bear of a powerplant to pull it at speed.
Old Sep 8, 2008 | 08:21 PM
Road Agent's Avatar
Road Agent
WTF is the question?
Old Sep 8, 2008 | 08:24 PM
LT4POWR's Avatar
LT4POWR
Old Sep 8, 2008 | 08:26 PM
JimiHendrix's Avatar
JimiHendrix
....joke is on you ROAD AGENT......question is in the heading....AHAHAHAHAHAHAHAHAAAA
Old Sep 8, 2008 | 08:27 PM
MK 82's Avatar
MK 82
A crap load more horsepower than you have.
To How much power needed to pull in 6th?
Old Sep 8, 2008 | 08:28 PM
MK 82's Avatar
MK 82
Aren't you dead?
What's one dead attorney at the bottom of the ocean?
Old Sep 8, 2008 | 08:29 PM
JimiHendrix
Originally Posted by MK 82
Aren't you dead?
shhhhhhhhhh!
Old Sep 8, 2008 | 08:31 PM
JimiHendrix
Aren't you dead?
dunno.......wha?
